Metrics settings in Kibana
You do not need to configure any settings to use the Metrics app in Kibana. It is enabled by default.
General metrics settings
- xpack.infra.sources.default.fields.message
Supported on:
Fields used to display messages in the Logs app.
Datatype:
stringDefault:
['message', '@message']Deprecation detailsDeprecated in 8.18.
- xpack.infra.alerting.inventory_threshold.group_by_page_size
Supported on:
Controls the size of the composite aggregations used by the Inventory Threshold to retrieve all the hosts.
Datatype:
intDefault:
5000 - xpack.infra.alerting.metric_threshold.group_by_page_size
Supported on:
Controls the size of the composite aggregations used by the Metric Threshold group by feature.
Datatype:
intDefault:
10000
