Loading
Run Elastic Agent on Azure AKS managed by Fleet
Follow the steps to run the Elastic Agent on Run Elastic Agent on Kubernetes managed by Fleet page.
On managed Kubernetes solutions like AKS, Elastic Agent has no access to several data sources. Find below the list of the non available data:
  1. Metrics from Kubernetes control plane components are not available. Consequently metrics are not available for kube-scheduler and kube-controller-manager components. In this regard, the respective dashboards will not be populated with data.
  2. Audit logs are available only on Kubernetes master nodes as well, hence cannot be collected by Elastic Agent.
  3. Fields orchestrator.cluster.name and orchestrator.cluster.url are not populated. orchestrator.cluster.name field is used as a cluster selector for default Kubernetes dashboards, shipped with Kubernetes integration.
    In this regard, you can use add_fields processor to add orchestrator.cluster.name and orchestrator.cluster.url fields for each Kubernetes integration's component:
    - add_fields:
        target: orchestrator.cluster
        fields:
          url: clusterURL
