editLogstash connection doesn’t workedit
You may have configured Logstash or Auditbeat incorrectly. To resolve the issue:
Make sure that Logstash is running and you can connect to it. First, try to ping the Logstash host to verify that you can reach it from the host running Auditbeat. Then use either
nc
ortelnet
- Verify that the config file for Auditbeat specifies the correct port where Logstash is running.
