Loading
Troubleshooting RAG Playground
Dense vectors are not searchable
Embeddings must be generated using the inference processor with an ML node.
Context length error
You’ll need to adjust the size of the context you’re sending to the model. Refer to Optimize model context.
LLM credentials not working
Under LLM settings, use the button to edit your GenAI connector settings.
Poor answer quality
Check the retrieved documents to verify if they are valid. Adjust your Elasticsearch queries to improve the relevance of the documents retrieved. Refer to View and modify queries.
You can update the initial instructions to be more detailed. This is called prompt engineering. Refer to this OpenAI guide for more information.
You might need to click ⟳ Clear chat to clear chat history and start a new conversation. If you mix topics, the model will find it harder to generate relevant responses.
