Index lifecycle management
Stack
Lifecycle policies allow you to automate the lifecycle of your APM indices as they grow and age. A default policy is applied to each APM data stream, but can be customized depending on your business needs.
In the latest version of Elastic APM, clusters are managed by index lifecycle management (ILM) to provide the default data retention settings for APM data as well as allow customization for lifecycle.
Indices created in 8.15.x and 8.16.x might be managed by data stream lifecycle (DSL). More details are available in APM version 8.15. By default, new indices created in 8.17 are managed by ILM. More details are available in APM version 8.17. If you have indices managed by DSL, any custom DSL settings that you specified will not automatically apply to the new indices managed by ILM. Instead, you can replicate custom DSL settings in ILM using this guide.
Each APM data stream has its own default lifecycle policy including a delete definition and a rollover definition.
The table below describes the delete definition for each APM data stream. The delete phase permanently removes the index after a time threshold is met.
Data stream | Delete after | Notes |
traces-apm |
10 days | Raw trace event data |
traces-apm.rum |
90 days | Raw RUM trace event data, used in the UI |
logs-apm.error |
10 days | Error event data |
logs-apm.app |
10 days | Logs event data |
metrics-apm.app |
90 days | Custom application specific metrics |
metrics-apm.internal |
90 days | Common system metrics and language specific metrics (for example, CPU and memory usage) |
metrics-apm.service_destination_1m |
90 days | Aggregated transaction metrics powering the Applications UI |
metrics-apm.service_destination_10m |
180 days | Aggregated transaction metrics powering the Applications UI |
metrics-apm.service_destination_60m |
390 days | Aggregated transaction metrics powering the Applications UI |
metrics-apm.service_summary_1m |
metrics-apm.service_summary_10m |
metrics-apm.service_summary_60m |
metrics-apm.service_transaction_1m |
metrics-apm.service_transaction_10m |
metrics-apm.service_transaction_60m |
metrics-apm.transaction_1m |
metrics-apm.transaction_10m |
metrics-apm.transaction_60m |
Rollover (writing to a new index) prevents a single index from growing too large and optimizes indexing and search performance. Rollover occurs after either an age or size metric is met.
Default lifecycle policies can change between minor versions. This is not considered a breaking change as index management should continually improve and adapt to new features.
Mappings and settings for data streams can be customized through the creation of *@custom
component templates, which are referenced by the index templates created by the Elasticsearch apm-data plugin. The easiest way to configure a custom index lifecycle policy per data stream is to edit this template.
This tutorial explains how to apply a custom index lifecycle policy to the traces-apm
data stream.
The Data Streams view in Kibana shows you data streams, index templates, and lifecycle policies:
To open Index Management, find Stack Management in the main menu or use the global search field.
Select Data Streams.
Search for
traces-apm
to see all data streams associated with APM trace data.In this example, I only have one data stream because I’m only using the
default
namespace. You may have more if your setup includes multiple namespaces.
- To open Lifecycle Policies, find Stack Management in the main menu or use the global search field.
- Click Create policy.
Name your new policy; For this tutorial, I’ve chosen custom-traces-apm-policy
. Customize the policy to your liking, and when you’re done, click Save policy.
To apply your new index lifecycle policy to the traces-apm-*
data stream, edit the <data-stream-name>@custom
component template.
Click on the Component Template tab and search for
traces-apm
.Select the
traces-apm@custom
template and click Manage → Edit.Under Index settings, set the ILM policy name created in the previous step:
{ "lifecycle": { "name": "custom-traces-apm-policy", "prefer_ilm": true } }
Continue to Review and ensure your request looks similar to the image below. If it does, click Create component template.
To confirm that the data stream is now using the new index template and ILM policy, you can either repeat step one, or navigate to Dev Tools and run the following:
GET /_data_stream/traces-apm-default
- The name of the data stream we’ve been hacking on appended with your <namespace>
The result should include the following:
"data_streams" : [
"template" : "traces-apm-default",
"ilm_policy" : "custom-traces-apm-policy",
- The name of the custom index template created in step three
- The name of the ILM policy applied to the new component template in step two
New ILM policies only take effect when new indices are created, so you either must wait for a rollover to occur (usually after 30 days or when the index size reaches 50 GB), or force a rollover using the Elasticsearch rollover API:
POST /traces-apm-default/_rollover/
It is also possible to create more granular index lifecycle policies that apply to individual namespaces. This process is similar to the above tutorial, but includes cloning and modify the existing index template to use a new *@custom
component template.
