Inspect and manage Knowledge Indicators in Context Engine
This page is currently hidden from the documentation navigation.
The following Context Engine pages are live:
Inspect Knowledge Indicators (KIs) in an AI index from Kibana, and change them through workflows. To correct generated context, update and rerun the owning automation. When a workflow needs to create, update, or delete individual KIs, use the dedicated Context Engine workflow steps.
Requirements depend on what you want to do:
- To inspect KIs:
- An AI index that contains at least one KI.
- The Read privilege for the Context Engine feature.
- The
readandview_index_metadataindex privileges on the backing index (ai-index-*).
- To create, update, or delete KIs:
- A custom AI index.
- The All privilege for the Context Engine feature.
- Permission to edit and run workflows.
- Elasticsearch write access to the backing index. If an operation creates the backing index, you also need permission to create it.
You can inspect KIs in a managed AI index, but you cannot manage them directly. The Elastic feature that provides the AI index controls their lifecycle.
The KI detail view shows the generated content and the metadata that identifies where it came from and when it changed.
- Find Context in the navigation menu or use the global search field.
- Open the AI index that contains the KI.
- Select the Knowledge Indicators tab.
- Optional: Filter the table by KI type.
- Select a KI.
- On the Content tab, review its generated content and metadata.
- Select the Document tab to inspect the complete stored document.
Confirm that the title, type, status, and timestamps identify the KI you expected. The KI workflow steps automatically record provenance, including the workflow ID and run ID. Inspect these fields on the Document tab when you need to trace a KI to the workflow run that wrote it; you do not need to populate them yourself.
The detail view is read-only. To assess whether the content is accurate and useful to an agent, refer to Evaluate and improve Knowledge Indicators.
Use Discover when you need to compare several raw KI documents or inspect their stored fields.
- On the AI index's Knowledge Indicators tab, select View raw docs in Discover.
- In Discover, filter the documents to the KI or set of KIs you want to inspect.
- Review their content, timestamps, lifecycle status, references, and provenance.
Use Discover for inspection. To retrieve KIs programmatically, use the list, describe, and query APIs described in Query with APIs. Manage KIs through their owning automation or the supported workflow steps instead of editing the backing index directly.
How you change a KI depends on how it was created and whether the change must survive future automation runs:
| Situation | Recommended action |
| Generated content is incomplete or incorrect | Edit the source or owning automation, then run the automation again. |
| A workflow maintains a long-lived KI across runs | Use context-engine.updateKi with a stable KI ID. |
| A workflow must write a new KI | Use context-engine.createKi. |
| A KI must no longer be retrieved | Use context-engine.deleteKi, then update its automation if another run would recreate it. |
| The KI belongs to a managed AI index | Do not change it directly. The Elastic feature that provides the AI index manages its KIs. |
Changing the automation is the preferred way to correct generated content because later runs reproduce the improvement. A direct update is appropriate when updating the KI is part of the workflow's intended design.
Add KI management steps to an existing automation or to another workflow that intentionally maintains KIs:
- Open the workflow in the Workflows YAML editor.
- Add the appropriate create, update, or delete step.
- Test the workflow and inspect the step output.
- Save and run the workflow.
- Return to the AI index's Knowledge Indicators tab and confirm the result.
The following examples show the inputs for each operation.
Use context-engine.createKi with verifiers to check a KI before writing it. This is the recommended approach when a KI must pass verification before it becomes available for retrieval. Set ki_id to a stable value when later runs must address the same logical KI.
The following example combines the built-in esql-valid-syntax verifier with a custom verifier workflow. check-ki-content is the name of the workflow defined in Add a custom verifier. Create and enable that workflow before running this step.
- name: create_ki
type: context-engine.createKi
with:
ai_index_id: "support-context"
ki_id: "account-123-support-connection-456-cases"
verifiers:
- "esql-valid-syntax"
- workflow_id: "check-ki-content"
ki:
type: "support.recurring_issue"
title: "Recurring support case patterns"
description: "Patterns found across the support cases analyzed by the workflow."
content: "The cases in this support connection describe configuration and capacity issues. Use this context when investigating recurring support problems for this account."
attributes:
account_id: "account-123"
connection_id: "support-connection-456"
object_id: "cases"
tags:
- "support"
- "recurring-issue"
Use attributes for structured identifiers that you need to filter on, such as the account, connection, and object represented by a KI. Use content to explain what the source contains and when it is useful. These attribute names are examples for this use case, not required KI fields. Storing an account or user identifier does not itself restrict access to the KI.
When one workflow writes KIs for multiple accounts or connections, give each logical KI a distinct, stable ki_id. The example combines the account, connection, and object identifiers so that later runs address the same KI without replacing another account's context.
For an index-backed AI index, another create operation with the same ki_id replaces the document. For a data-stream-backed AI index, it appends a revision.
When verification passes, the step writes the KI and returns its id and the verification results. If any verifier fails, the step returns verification.passed: false without an id and does not write the KI. Inspect verification.results for the outcome of each verifier. A completed step does not by itself mean that a KI was written.
For KIs that contain ES|QL, you can also add the built-in esql-valid-syntax and esql-valid-runtime verifiers. Parsing and running a query does not establish that it answers the intended question.
A custom verifier is a workflow that receives the candidate KI as inputs.ki and returns a boolean passed result, with an optional reason. Create and enable the workflow in the same Kibana space as the calling workflow. In the verifiers list, set workflow_id to the verifier workflow's ID. Kibana derives the ID from the workflow's name when you create it, so the ID for this example is check-ki-content.
For example, this verifier rejects a KI when its content field is missing or empty:
enabled: true
triggers:
- type: manual
inputs:
- name: ki
type: object
required: true
outputs:
- name: passed
type: boolean
- name: reason
type: string
steps:
- name: check_content
type: if
condition: 'inputs.ki.content: * and not inputs.ki.content: ""'
steps:
- name: accept_ki
type: workflow.output
with:
passed: true
reason: "The KI has content."
else:
- name: reject_ki
with:
passed: false
reason: "The KI content is missing or empty."
Test the verifier with a KI that contains content and one that does not. Confirm that it returns passed: true and passed: false, respectively. This example checks only whether content is present. Add checks appropriate to your use case to assess the generated information.
For the workflow input and output contract, refer to Compose workflows from reusable parts > Design the input and output contract.
Use context-engine.verifyKi when your workflow needs to decide what to do with verification results independently of writing a KI. For example:
- Verify a candidate before creation, inspect the results, and intentionally write it even if a check fails. In this case, call
context-engine.createKiwithoutverifiersafter applying your workflow's decision logic. - Retrieve existing KIs in a separate workflow, verify them, and use
context-engine.deleteKito remove those that fail the required checks.
The step accepts the KI document and the same verifiers list as context-engine.createKi. It returns passed and results without writing, updating, or deleting the KI. Your workflow must explicitly perform any subsequent action.
Use context-engine.updateKi to change selected fields of an existing KI. Fields that you omit remain unchanged, while arrays that you provide replace the existing arrays.
- name: update_ki
type: context-engine.updateKi
with:
ki:
description: "Reviewed patterns found across recent support cases."
tags:
- "support"
- "recurring-issue"
- "reviewed"
The step returns updated when it changes the KI and noop when the supplied values already match the stored document. It fails if the AI index or KI does not exist.
For an index-backed AI index, the step updates the stored document. For a data-stream-backed AI index, it appends a revision with the supplied changes.
Use context-engine.deleteKi to prevent a KI from appearing in normal retrieval results.
- name: delete_ki
type: context-engine.deleteKi
with:
For an index-backed AI index, the step removes the document. For a data-stream-backed AI index, it marks the KI as deleted and preserves its revisions. A deleted KI can therefore remain visible in the inspection UI with the Deleted status.
Deleting a KI does not change the workflow that generated it. If a later run would recreate the KI, update or stop that automation as well.
KI write operations do not wait for an Elasticsearch refresh by default. Set refresh: true when a later step in the same workflow run must immediately read, update, or delete the KI.
After the workflow runs, confirm the intended outcome:
- Inspect the management step in the workflow execution and confirm that it completed successfully.
- Open the AI index's Knowledge Indicators tab.
- Find the KI by its title and type, then open its details.
- Confirm that its ID, content, update time, status, and provenance match the workflow run.
- If the KI includes identifying attributes, confirm that they match the intended account, connection, and source object.
If the workflow completed but the expected KI was not written, inspect any configured verifier results. Verification failure prevents context-engine.createKi from writing the KI.
