Query AI indices from LangChain
This page is currently hidden from the documentation navigation.
The following Context Engine pages are live:
A LangChain agent can retrieve Knowledge Indicators (KIs) from Context Engine using read-only tools.
For agent-specific access, instructions, and testing guidance, refer to Configure agents to use an AI index.
To connect a LangChain agent to Context Engine, use the Context Engine APIs to wrap the available retrieval operations as LangChain tools in your application.
Examples on this page use Python, but the same approach works in LangChain.js.
Before you begin, make sure you have:
- An Elastic Stack deployment with an Enterprise license, or an Elastic Cloud Serverless project.
- The
contextEngine:enabledadvanced setting turned on in the space you want to query. This setting is per space, and the APIs return404in any space where it's off. - At least one AI Index containing Knowledge Indicators (KIs). See Create an AI Index if you don't have one yet.
- An API key whose privileges cover both Kibana and Elasticsearch. Step 1 walks through this.
- Python 3.10 or later, with
langchaininstalled. The skill option in Step 3 addsdeepagents, which needs 3.11 or later.
Context Engine uses a list, describe, and query sequence to retrieve KIs. For the available query modes and complete retrieval workflow, refer to Retrieve context from an AI index.
All three operations run against one Kibana space, as the owner of the API key. An agent only ever sees the AI Indices that key is allowed to read.
Your credential needs privileges in both Kibana and Elasticsearch.
Create the credential as follows:
In Kibana, go to Stack Management → API Keys and click
Create API keyLeave Control security privileges off and define a role with the following privileges:
- Index privileges:
readandview_index_metadataonai-index-*. - Kibana privileges, in the space you want to query: Context Engine at Read.
Example of a concrete definition{ "contextEngineRole": { "cluster": [], "indices": [ { "names": [ "ai-index-*" ], "privileges": [ "read", "view_index_metadata" ], "field_security": { "grant": [ "*" ], "except": [] }, "allow_restricted_indices": false } ], "applications": [ { "application": "kibana-.kibana", "privileges": [ "feature_contextEngine.read" ], "resources": [ "*" ] } ], "run_as": [], "metadata": {}, "transient_metadata": { "enabled": true } } }- Index privileges:
Copy the
encodedvalue and export it, along with your Kibana URL:export KIBANA_URL="https://my-deployment.kb.us-east-1.aws.elastic.cloud" export KIBANA_API_KEY="VnVhQ2ZHY0JDZGJrU..."
This example also uses an OpenRouter key to reach the model:
export OPENROUTER_API_KEY="sk-..."
Each tool wraps one endpoint. The docstrings are the only instructions the model gets about how and when to call them, so they carry the ordering and the constraints.
The following API references define the request and response schemas used by the tools:
Every request needs these headers:
| Header | Value | Notes |
Authorization |
ApiKey <encoded key> |
The encoded value returned when you create the key. |
elastic-api-version |
2023-10-31 |
Required on all three endpoints. Without it the request fails with 400. |
kbn-xsrf |
true |
Required for the POST request on self-managed and Elastic Cloud Hosted deployments. Harmless elsewhere, so always send it. |
import os
import httpx
from langchain.tools import tool
kibana = os.environ["KIBANA_URL"].rstrip("/")
space = os.environ.get("KIBANA_SPACE")
base = f"{kibana}/s/{space}" if space else kibana
client = httpx.Client(
base_url=f"{base}/api/context_engine",
headers={
"Authorization": f"ApiKey {os.environ['KIBANA_API_KEY']}",
"elastic-api-version": "2023-10-31",
"kbn-xsrf": "true",
"Content-Type": "application/json",
timeout=60,
@tool
def list_ai_indices() -> list[dict]:
"""List the AI Indices available in this space, with the ES|QL target to query each
one against. Call this first, before describing or querying anything."""
response = client.get("/ai_index")
response.raise_for_status()
return [
"id": entry["id"],
"esql_target": entry["dest"]["value"],
"description": entry.get("description"),
for entry in response.json()["ai_indices"]
@tool
def describe_ai_index(ai_index_id: str) -> str:
"""Describe one AI Index: the ES|QL target to put after FROM, every field it exposes
and which are semantic, the knowledge indicator types and tags it holds, and example
queries. Always call this before writing a query against an index."""
response = client.get(f"/ai_index/{ai_index_id}/_describe")
return response.json()["response"]
@tool
def query_ai_indices(query: str, params: dict | None = None, limit: int = 20) -> dict:
"""Run an ES|QL query against one or more AI Indices and return {columns, values}.
Build the query from the output of describe_ai_index: use its FROM target and its
field names verbatim. Pass user input as named parameters in params rather than
writing it into the query string. Do not add any space, tenant, or permissions
condition to the query."""
body = {"query": query, "limit": limit}
if params:
body["params"] = params
response = client.post("/ai_index/_query", json=body)
The annotations explain the following details:
- Set
KIBANA_SPACEto target a non-default space. Leave it unset for the default space. - Required on all three endpoints. Without it the request fails with
400. - Required for
POSTon self-managed and Elastic Cloud Hosted deployments. Harmless elsewhere. - The API response nests the ES|QL target under
dest.value. The example surfaces it asesql_targetfor clarity.
Each entry the list operation returns gives the agent:
id, to pass to the describe operation.esql_target, the exact string to put afterFROM. Use it verbatim: it differs from the ID (sales-knowledgebecomesai-index-idx-sales-knowledge) and can be a wildcard or a data stream.description, to determine whether the AI Index is relevant to the question.managed, to distinguish a built-in AI Index supplied by an Elastic feature from one created by a user.
The list omits an AI Index when your credential can't read its backing index. It does include an AI Index that's registered but still empty.
The agent needs a model, the tools from Step 2, and instructions telling it to follow the list, describe, query flow. You can supply those instructions two ways:
- System instructions: a prompt string in your script. Everything stays in one file, which suits a single application.
- A skill: a
SKILL.mdfile that you write and keep outside your script. One copy serves every agent that loads it, and the agent reads the full instructions only when it judges them relevant.
from langchain.agents import create_agent
from langchain_openai import ChatOpenAI
SYSTEM_PROMPT = """\
You have access to Elastic Context Engine knowledge through three tools.
To answer a question from that knowledge:
1. Call list_ai_indices to see what is available.
2. Call describe_ai_index on the index you pick.
3. Call query_ai_indices with ES|QL built from that description.
Never guess an index ID, an ES|QL target, or a field name — the describe output gives you
all three. The server applies the space and permissions condition, so never add one to a query.
Answer from the rows you get back and cite the Knowledge Indicator titles.
def main() -> None:
llm = ChatOpenAI(
model="anthropic/claude-sonnet-4-6",
openai_api_key=os.environ["OPENROUTER_API_KEY"],
openai_api_base="https://openrouter.ai/api/v1",
agent = create_agent(llm, [list_ai_indices, describe_ai_index, query_ai_indices])
The annotation explains the following detail:
- This example routes through OpenRouter. Replace
openai_api_baseand the corresponding API key to use a different LLM provider.
SkillsMiddleware applies progressive disclosure: at startup it reads each skill's frontmatter and puts only the name and description into the system prompt. The agent reads the full SKILL.md with read_file when it decides the skill applies, then pulls in supporting files only as the instructions call for them. The tool-calling rules stay out of the context window until they're needed.
Write the skill yourself, so it names your tools and states the rules your agent has to follow. The frontmatter needs a name and a description, and the name has to match the directory that holds the file. The description is all the agent sees until it opens the file, so write it around the questions the skill helps answer.
The following SKILL.md covers the retrieval flow for the tools from Step 2. Save it as skills/context-engine-retrieval/SKILL.md, next to your script:
description: Retrieve Knowledge Indicators from Elastic Context Engine AI Indices. Use when a question is likely answered by recurring internal knowledge, such as policies, runbooks, or past investigation findings.
# Retrieve context from Elastic Context Engine
Elastic Context Engine knowledge is available through three tools: `list_ai_indices`,
`describe_ai_index`, and `query_ai_indices`.
## Retrieval flow
1. Call `list_ai_indices` to see which AI Indices you can read.
2. Pick the AI Index whose description matches the question, then call `describe_ai_index` on it.
3. Call `query_ai_indices` with an ES|QL query built from that description.
## Rules
- Never guess an index ID, an ES|QL target, or a field name. The describe output gives you all three.
- Use the `FROM` target from the describe output verbatim.
- Pass user input as named parameters rather than writing it into the query string.
- The server applies the space and permissions condition, so never add one to a query.
- Answer from the rows you get back and cite the Knowledge Indicator titles.
Create the agent with the skills middleware instead of a system prompt. Skills come from the deepagents package, which needs Python 3.11 or later.
from pathlib import Path
from deepagents.backends import StateBackend
from deepagents.backends.utils import create_file_data
from deepagents.middleware import FilesystemMiddleware, SkillsMiddleware
from langgraph.checkpoint.memory import InMemorySaver
SKILL_PATH = Path(__file__).parent / "skills/context-engine-retrieval/SKILL.md"
def main() -> None:
# ...llm as in the system instructions example...
backend = StateBackend()
skill_files = {
"/skills/context-engine-retrieval/SKILL.md": create_file_data(
SKILL_PATH.read_text()
llm,
[list_ai_indices, describe_ai_index, query_ai_indices],
middleware=[
FilesystemMiddleware(backend=backend),
SkillsMiddleware(backend=backend, sources=["/skills/"]),
checkpointer=InMemorySaver(),
- Reads the skill once, at startup, and seeds the agent's virtual filesystem with it. The directory name under
/skills/has to match thenamein the skill's frontmatter. - Gives the agent the
read_filetool that the read stage depends on. Without it the agent can see each skill's description but can't open the instructions. - Scans
/skills/and puts every skill it finds into the system prompt, name and description only. StateBackendholds the skill files in the graph's state, scoped to a single thread, so skills need acheckpointerfor that state to be stored against. SwapInMemorySaverfor a durablecheckpointerto keep a thread beyond the life of the process.
Invoke the agent with a question that the Knowledge Indicators in your AI Index can answer. The following question is an example.
def main() -> None:
# ...agent from Step 3...
result = agent.invoke(
"messages": [
{"role": "system", "content": SYSTEM_PROMPT},
{"role": "user", "content": "What is our refund policy for annual plans?"},
print(result["messages"][-1].content)
if __name__ == "__main__":
main()
def main() -> None:
"messages": [
"files": skill_files,
config={"configurable": {"thread_id": "1"}},
main()
A successful run shows the agent working through the retrieval flow in order. Check that:
- It called the list tool and got back at least one AI Index.
- It called the describe tool on the index it selected.
- Its query used the target and field names returned by
describe, not invented ones. - The answer draws on Knowledge Indicator content, and names the indicators it used.
If the agent answers without calling the tools, or queries a target that describe never returned, the instructions aren't reaching it. Check that the system message is attached, or that the skill loaded, before looking at privileges. To see the calls it made, inspect result["messages"] rather than only the final entry.
Set KIBANA_SPACE to the space ID before creating the client, so requests go to /s/{space_id}/api/context_engine. The API key needs the Context Engine feature privilege in that space, and contextEngine:enabled has to be on there.
Each AI Index belongs to one space, so the list tool returns only the AI Indices in the space that the client targets. The same AI Index ID can refer to different AI Indices in different spaces.
To read from several spaces in one agent, build one client per space and register a separate set of tools for each.
For common access and retrieval failures, refer to Troubleshoot retrieval.
Here is the full end-to-end Python script using the system prompt option from Step 3:
demo_api.py
import os
import httpx
_kibana = os.environ["KIBANA_URL"].rstrip("/")
_space = os.environ.get("KIBANA_SPACE")
_base = f"{_kibana}/s/{_space}" if _space else _kibana
base_url=f"{_base}/api/context_engine",
headers={
"kbn-xsrf": "true",
timeout=60,
@tool
return [
"id": entry["id"],
@tool
@tool
if params:
def main() -> None:
llm = ChatOpenAI(
"messages": [
main()
Additionally, take a look at the same script using the skill option from Step 3:
demo_api_skill.py
import os
import httpx
headers={
"kbn-xsrf": "true",
timeout=60,
@tool
return [
"id": entry["id"],
@tool
@tool
if params:
def main() -> None:
skill_files = {
llm = ChatOpenAI(
llm,
middleware=[
"messages": [
main()
Here's an example of a pyproject.toml with the dependencies for the above scripts:
[dependency-groups]
dev = [
"deepagents>=0.7",
"langchain>=1.4.0",
"langchain-openai>=1.6.2",
- needed for skills instead of system prompts and requires Python 3.11+
- only needed for this example or if you want to use OpenAI or OpenRouter LLMs
