Build and maintain an AI index
Building a useful AI index starts with decisions about its purpose, source data, Knowledge Indicator (KI) granularity, and refresh schedule. Use this page to plan those decisions before creating or revising an automation.
This page covers AI indices that you create and maintain. Elastic features can also supply managed AI indices whose configuration is read-only.
For a UI-led example that creates and tests an AI index, follow the Context Engine quickstart.
Start with the recurring questions that the AI index should help answer. Use them to define its subject, boundaries, and intended users or agents. A narrow purpose makes it easier to select relevant source data and evaluate whether the generated KIs are useful.
Give the AI index a name and description that distinguish it from other available context. Agents use this metadata to decide whether the AI index is relevant before they retrieve its KIs.
To create, update, or delete one, refer to Create and manage AI indices.
Source selection identifies the data that an AI index is intended to use and informs automation suggestions. An ES|QL source can combine or filter data from multiple Elasticsearch indices. Connector sources identify data outside Elasticsearch.
Start with a source whose result represents the data you want the automation to analyze. Confirm that it contains the information needed for the KIs you want to generate, and record any filters, sampling, or freshness limits that affect interpretation.
Avoid adding data only because it is available. Unrelated records increase the work required to generate and retrieve context and make the boundaries of resulting claims harder to understand.
To update the source selection, refer to Add and manage sources.
Select a strategy based on what each KI needs to represent. For example, one KI can describe an entire dataset, several KIs can capture atomic facts from the same document, or a long-lived KI can accumulate a profile for one entity.
Strategy What each KI represents Useful for
Index or table metadata One data source Explaining what a dataset contains, when to use it, and how to query it
Bottom-up One source document Bounded collections of articles, cases, product documentation, or other substantial records
Selective or outlier One significant record Event or log data where unusual records matter more than routine records
Atomic facts One specific fact, with several KIs extracted from one document Information-dense material where a document-level summary would lose important details
Cumulative entity profile One profile that is enriched as an entity recurs Services, hosts, accounts, projects, or other entities represented across many records
Detection or feature One named condition or entity feature Runnable detection logic or a structured inventory of observed capabilities and characteristics
The questions the AI index must answer determine the useful granularity. A dataset-level KI can orient an agent to a source, entity profiles can preserve knowledge that develops across records, and selective KIs can surface only the events that warrant attention. Prefer fewer, substantial KIs over many thin KIs that repeat the source documents.
A useful KI adds context that an agent cannot get from field mappings alone. Depending on the use case, capture:
  • Business meaning and relationships in the data.
  • Derived findings that help answer recurring questions.
  • Known limitations or boundaries of the source.
  • Verified query patterns for retrieving current details from source data.
KIs can reduce the time and model tokens agents spend exploring source data. When an answer depends on current or detailed information, the KI can direct the agent to a targeted source query.
Review an automation before its first run, whether Elastic Agent Builder suggested it or you authored it through the Workflows UI or APIs. For an Elastic Agent Builder suggestion, review the proposal before you confirm it. Check:
  • Which sources and additional queries the Workflow reads.
  • Which KI generation strategy and type it uses.
  • How much source data each KI represents.
  • Which claims, query patterns, and references the KI contains.
  • How the Workflow verifies its output before writing the KI.
Reviewing these decisions before the first run limits unnecessary model calls and makes the resulting context easier to evaluate.
To create and operate the Workflow, refer to Create and manage automations.
After an automation runs, inspect its KIs for accuracy, useful interpretation, source limitations, and stable identifiers. Test the context with recurring questions, questions that require current source data, and questions outside the AI index's scope.
Where agent traces are available, look for empty retrievals, query errors, broad source exploration, and repeated sequences of tool calls. These behaviors can reveal missing context, weak retrieval metadata, or query guidance that the automation should generate in advance.
Use those observations to revise the AI index description, source coverage, generation strategy, automation instructions, or refresh schedule. Run the automation again and compare the resulting KIs and agent behavior. Improving the automation makes the change repeatable for later runs and for every agent that uses the AI index.
To find and manage individual KIs, refer to Inspect and manage Knowledge Indicators. For a structured quality review, refer to Evaluate and improve Knowledge Indicators.
For definitions of the objects involved, refer to Context Engine concepts. To make the resulting context available to an agent or application, refer to Use an AI index.
