Loading
Managing cross-project search scope in your project apps
When cross-project search (CPS) is enabled and projects are linked, searches initiated from your project's apps run across all linked projects by default. Kibana provides several ways to narrow or change this scope:
  • Space default: Admins configure a default scope for each space, which applies when you start a new session.
  • Session scope: Use the CPS scope selector in the project's header to change which projects are searched during your session.
  • Query-level override: Use project routing or qualified index expressions in individual queries to target specific projects.
The Cross-project search (CPS) scope selector ( ) in your project's header lets you control which linked projects your searches include.
With the CPS scope selector, you can select:
  • This project: Searches only the origin project.
  • All projects: Searches the origin project and all linked projects.
Tip
The scope selector also lists the aliases of all linked projects, which is useful when you need to reference them in queries or index patterns.
The scope selector is not editable in every app. Some apps display it as read-only, meaning the app uses the space default scope but you cannot change it. Other apps show it as unavailable, meaning the app searches only the current project. Refer to Cross-project search availability by app for details.
When you change the scope during a session, your selection is preserved as you navigate between apps. Admins can configure a default cross-project search scope for each space, which is used when you start a new session.
In apps where you write queries, you can define a different cross-project search scope than the one set in the header's scope selector or the space-level default. This is useful when you want a specific query or dashboard panel to search a different set of projects.
There are two main mechanisms:
  • Project routing: Use a project_routing parameter to limit which projects a query runs against. In ES|QL, use SET project_routing at the beginning of your query. Project routing is evaluated before query execution, so excluded projects are never queried.
  • Qualified index expressions: Prefix an index name with a project alias to target a specific project, for example my_project:logs-*. Qualified expressions work in index patterns and query source commands.
For example, to search only a specific linked project from Discover, start your ES|QL query with:
SET project_routing="_alias:my-project";
FROM logs-*
| LIMIT 100
Not all apps support cross-project search. The following table shows which apps support the CPS scope selector and query-level overrides. Any app with an ES|QL editor supports SET project_routing and qualified index expressions in FROM commands.
App CPS scope selector Query-level overrides
Agent Builder Not available ES|QL
Dashboards Editable Per-panel overrides using ES|QL visualizations or Maps layer routing. Dashboards can also store a cross-project search scope.
Dev Tools / Console Not available Full CPS through raw API requests, including ES|QL. The Painless execute API resolves index names differently.
Discover Editable ES|QL
Lens visualizations Editable ES|QL visualizations1
Maps Editable Layer-level project routing for vector layers and joins
Machine Learning AIOps Labs Editable Not available
Machine Learning Data Visualizer Editable ES|QL
Rules and alerts Read-only ES|QL rules support SET project_routing. For non-ES|QL rules that use index patterns, you can use qualified index expressions to scope the rule to specific projects.
Streams Not available ES|QL
Vega Editable Project routing in Vega specs
The header's CPS scope selector is not available in other apps, including Transforms, Canvas, and object listing pages.
Observability apps have limited CPS support. The scope selector is not available in Observability apps, and most apps remain scoped to the origin project. The following table shows how each Observability app behaves with CPS:
Observability app CPS availability
APM (Service Inventory, Traces, Dependencies) Available (scope selector available)
Infrastructure (Inventory, Hosts) Available (scope selector available)
Observability Overview (Hosts, Log Events, Service Inventory) Not available
Observability AI Assistant Not available
SLOs Not available
Rules (Custom Threshold, SLO Burn Rate) Read-only
Synthetics (monitors, TLS Certificates) Not available
For specific app details, refer to Cross-project search in Observability.
Elastic Security apps have limited CPS support:
  • Timeline: Only the ES|QL tab supports SET project_routing. All other Timeline tabs search the origin project only.
  • Other Security features: The Explore page, threat-hunting workflows, the alert details flyout, and entity store remain scoped to the origin project.
  • Alerting: During technical preview, rules that query data across linked projects can generate alerts, and you can view those alerts in the UI. However, the alert response workflow, which includes actions after an alert is raised, such as triage, investigation, and case management across linked projects, is not yet fully supported with CPS.
Footnotes
  1. When a visualization panel uses a query-level override, it displays a Custom CPS scope badge on dashboards to indicate that it uses a different scope than the CPS scope selector.
