Configuring system settings
editConfiguring system settingsedit
Where to configure systems settings depends on which package you have used to install Elasticsearch, and which operating system you are using.
When using the .zip
or .tar.gz
packages, system settings can be configured:
Temporarily with
ulimit
Permanently in
/etc/security/limits.conf
When using the RPM or Debian packages, most system settings are set in the system configuration file. However, systems which use systemd require that system limits are specified in a systemd configuration file.
ulimit
On Linux systems, ulimit
can be used to change resource limits on a
temporary basis. Limits usually need to be set as root
before switching to
the user that will run Elasticsearch. For example, to set the number of
open file handles (ulimit -n
) to 65,535, you can do the following:
Become |
Change the max number of open files. |
Become the |
The new limit is only applied during the current session.
You can consult all currently applied limits with ulimit -a
On Linux systems, persistent limits can be set for a particular user by
editing the /etc/security/limits.conf
file. To set the maximum number of
open files for the elasticsearch
user to 65,535, add the following line to
the limits.conf
file:
elasticsearch - nofile 65535
This change will only take effect the next time the elasticsearch
user opens
a new session.
Ubuntu and limits.conf
Ubuntu ignores the limits.conf
file for processes started by init.d
. To
enable the limits.conf
file, edit /etc/pam.d/su
and uncomment the
following line:
# session required pam_limits.so
Sysconfig fileedit
When using the RPM or Debian packages, environment variables can be specified in the system configuration file, which is located in:
RPM |
Debian |
However, system limits need to be specified via systemd.
Systemd configurationedit
When using the RPM or Debian packages on systems that use systemd, system limits must be specified via systemd.
The systemd service file (/usr/lib/systemd/system/elasticsearch.service
contains the limits that are applied by default.
To override them, add a file called
/etc/systemd/system/elasticsearch.service.d/override.conf
(alternatively,
you may run sudo systemctl edit elasticsearch
which opens the file
automatically inside your default editor). Set any changes in this file,
such as:
[Service] LimitMEMLOCK=infinity
Once finished, run the following command to reload units:
sudo systemctl daemon-reload
