Monitoring Settings in Elasticsearchedit
By default, monitoring is enabled but data collection is disabled. To enable
data collection, use the xpack.monitoring.collection.enabled
setting.
You can configure these monitoring settings in the elasticsearch.yml
file.
Some of them can also be set across the cluster by using the
cluster update settings API.
Cluster settings take precedence over settings in the elasticsearch.yml
file.
To adjust how monitoring data is displayed in the monitoring UI, configure
xpack.monitoring
settings in
kibana.yml
. To control how monitoring data is collected from
Logstash, configure
xpack.monitoring
settings
in logstash.yml
General Monitoring Settingsedit
xpack.monitoring.enabled
Set to
true
(default) to enable Elasticsearch X-Pack monitoring for Elasticsearch on the node.To enable data collection, you must also set
totrue
. Its default value isfalse
Monitoring Collection Settingsedit
The xpack.monitoring.collection
settings control how data is collected from
your Elasticsearch nodes.
Set to
true
to enable the collection of monitoring data. When this setting isfalse
(default), Elasticsearch monitoring data is not collected and all monitoring data from other sources such as Kibana, Beats, and Logstash is ignored.You can update this setting through the Cluster Update Settings API.
xpack.monitoring.collection.interval
Setting to
-1
to disable data collection has been deprecated.
Controls how often data samples are collected. Defaults to 10s
. If you
modify the collection interval, set the xpack.monitoring.min_interval_seconds
option in kibana.yml
to the same value.
+ You can update this setting through the Cluster Update Settings API.
xpack.monitoring.collection.cluster.stats.timeout
Sets the timeout for collecting the cluster statistics. Defaults to
10s
xpack.monitoring.collection.indices
Controls which indices Monitoring collects data from. Defaults to all indices. Specify the index names as a comma-separated list, for example
test1,test2,test3
. Names can include wildcards, for exampletest*
. You can explicitly include or exclude indices by prepending+
to include the index, or-
to exclude the index. For example, to include all indices that start withtest
excepttest3
, you could specify+test*,-test3
xpack.monitoring.collection.index.stats.timeout
Sets the timeout for collecting index statistics. Defaults to
10s
xpack.monitoring.collection.index.recovery.active_only
Controls whether or not all recoveries are collected. Set to
true
to collect only active recoveries. Defaults tofalse
xpack.monitoring.collection.index.recovery.timeout
Sets the timeout for collecting the recovery information. Defaults to
10s
xpack.monitoring.history.duration
Sets the retention duration beyond which the indices created by a Monitoring exporter are automatically deleted. Defaults to
7d
(7 days).This setting has a minimum value of
1d
(1 day) to ensure that something is being monitored, and it cannot be disabled.This setting currently only impacts
local
-type exporters. Indices created using thehttp
exporter will not be deleted automatically.If both X-Pack monitoring and Watcher are enabled, you can use this setting to affect the Watcher cleaner service too. For more information, see the
xpack.watcher.history.cleaner_service.enabled
setting in the Watcher Settings. -
xpack.monitoring.exporters
- Configures where the agent stores monitoring data. By default, the agent uses a local exporter that indexes monitoring data on the cluster where it is installed. Use an HTTP exporter to send data to a separate monitoring cluster. For more information, see local exporter settings, HTTP exporter settings, and How it works.
Local Exporter Settingsedit
The local
exporter is the default exporter used by Monitoring. As the name is
meant to imply, it exports data to the local cluster, which means that there
is not much needed to be configured.
If you do not supply any exporters, then Monitoring will automatically create one for you. If any exporter is provided, then no default is added.
xpack.monitoring.exporters.my_local: type: local
type
The value for a Local exporter must always be
local
and it is required. -
use_ingest
Whether to supply a placeholder pipeline to the cluster and a pipeline processor with
every bulk request. The default value is
true
. If disabled, then it means that it will not use pipelines, which means that a future release cannot automatically upgrade bulk requests to future-proof them. -
cluster_alerts.management.enabled
Whether to create cluster alerts for this cluster. The default value is
true
. To use this feature, Watcher must be enabled. If you have a basic license, cluster alerts are not displayed.
HTTP Exporter Settingsedit
The following lists settings that can be supplied with the http
exporter.
All settings are shown as what follows the name you select for your exporter:
xpack.monitoring.exporters.my_remote: type: http host: ["host:port", ...]
type
The value for an HTTP exporter must always be
http
host
Host supports multiple formats, both as an array or as a single value. Supported formats include
hostname
,hostname:port
,http://hostname
http://hostname:port
,https://hostname
, andhttps://hostname:port
. Hosts cannot be assumed. The default scheme is alwayshttp
and the default port is always9200
if not supplied as part of thehost
string.xpack.monitoring.exporters: example1: type: http host: "10.1.2.3" example2: type: http host: ["http://10.1.2.4"] example3: type: http host: ["10.1.2.5", "10.1.2.6"] example4: type: http host: ["https://10.1.2.3:9200"]
auth.username
The username is required if a
auth.password
is supplied. -
auth.password
The password for the
auth.username
connection.timeout
The amount of time that the HTTP connection is supposed to wait for a socket to open for the
6s
connection.read_timeout
send back a response. The default value is
10 * connection.timeout
(60s
if neither are set). -
ssl
- Each HTTP exporter can define its own TLS / SSL settings or inherit them. See the TLS / SSL section below.
proxy.base_path
The base path to prefix any outgoing request, such as
/base/path
(e.g., bulk requests would then be sent as/base/path/_bulk
). There is no default value. -
headers
Optional headers that are added to every request, which can assist with routing requests through proxies.
xpack.monitoring.exporters.my_remote: headers: X-My-Array: [abc, def, xyz] X-My-Header: abc123
Array-based headers are sent
n
times wheren
is the size of the array.Content-Type
andContent-Length
cannot be set. Any headers created by the Monitoring agent will override anything defined here. -
index.name.time_format
A mechanism for changing the default date suffix for the, by default, daily Monitoring indices.
YYYY.MM.DD
, which is why the indices are created daily. -
use_ingest
Whether to supply a placeholder pipeline to the monitoring cluster and a pipeline processor with
true
true
. To use this feature, Watcher must be enabled. If you have a basic license, cluster alerts are not displayed. -
cluster_alerts.management.blacklist
Prevents the creation of specific cluster alerts. It also removes any applicable watches that already exist in the current cluster.
You can add any of the following watch identifiers to the blacklist:
elasticsearch_cluster_status
elasticsearch_version_mismatch
elasticsearch_nodes
kibana_version_mismatch
logstash_version_mismatch
xpack_license_expiration
For example:
["elasticsearch_version_mismatch","xpack_license_expiration"]
X-Pack monitoring TLS/SSL Settingsedit
You can configure the following TLS/SSL settings. If the settings are not configured, the Default TLS/SSL Settings are used.
xpack.monitoring.exporters.$NAME.ssl.supported_protocols
Supported protocols with versions. Valid protocols:
SSLv2Hello
,SSLv3
,TLSv1
,TLSv1.1
,TLSv1.2
. Defaults toTLSv1.2
,TLSv1.1
,TLSv1
. Defaults to the value ofxpack.ssl.supported_protocols
xpack.monitoring.exporters.$NAME.ssl.verification_mode
Controls the verification of certificates. Valid values are
none
,certificate
, andfull
. Seexpack.ssl.verification_mode
for a description of these values. Defaults to the value ofxpack.ssl.verification_mode
xpack.monitoring.exporters.$NAME.ssl.cipher_suites
Supported cipher suites can be found in Oracle’s
Java Cryptography Architecture documentation. Defaults to the value of
xpack.ssl.cipher_suites
X-Pack monitoring TLS/SSL Key and Trusted Certificate Settingsedit
The following settings are used to specify a private key, certificate, and the trusted certificates that should be used when communicating over an SSL/TLS connection. A private key and certificate are optional and would be used if the server requires client authentication for PKI authentication. If none of the settings below are specified, the Default TLS/SSL Settings are used.
PEM Encoded Filesedit
When using PEM encoded files, use the following settings:
xpack.monitoring.exporters.$NAME.ssl.key
- Path to a PEM encoded file containing the private key.
xpack.monitoring.exporters.$NAME.ssl.key_passphrase
- The passphrase that is used to decrypt the private key. This value is optional as the key might not be encrypted.
xpack.monitoring.exporters.$NAME.ssl.secure_key_passphrase
(Secure) - The passphrase that is used to decrypt the private key. This value is optional as the key might not be encrypted.
xpack.monitoring.exporters.$NAME.ssl.certificate
- Path to a PEM encoded file containing the certificate (or certificate chain) that will be presented when requested.
xpack.monitoring.exporters.$NAME.ssl.certificate_authorities
- List of paths to the PEM encoded certificate files that should be trusted.
Java Keystore Filesedit
When using Java keystore files (JKS), which contain the private key, certificate and certificates that should be trusted, use the following settings:
xpack.monitoring.exporters.$NAME.ssl.keystore.path
- Path to the keystore that holds the private key and certificate.
xpack.monitoring.exporters.$NAME.ssl.keystore.password
- Password to the keystore.
xpack.monitoring.exporters.$NAME.ssl.keystore.secure_password
(Secure) - Password to the keystore.
xpack.monitoring.exporters.$NAME.ssl.keystore.key_password
Password for the private key in the keystore. Defaults to the
same value as
xpack.monitoring.exporters.$NAME.ssl.keystore.secure_key_password
(Secure) - Password for the private key in the keystore.
xpack.monitoring.exporters.$NAME.ssl.truststore.path
- Path to the truststore file.
xpack.monitoring.exporters.$NAME.ssl.truststore.password
- Password to the truststore.
xpack.monitoring.exporters.$NAME.ssl.truststore.secure_password
(Secure) - Password to the truststore.
PKCS#12 Filesedit
X-Pack security can be configured to use PKCS#12 container files (.p12
or .pfx
files)
that contain the private key, certificate and certificates that should be trusted.
PKCS#12 files are configured in the same way as Java Keystore Files:
- Path to the PKCS#12 file that holds the private key and certificate.
xpack.monitoring.exporters.$NAME.ssl.keystore.type
Set this to
PKCS12
to indicate that the keystore is a PKCS#12 file. -
- Password to the PKCS#12 file.
(Secure) - Password to the PKCS#12 file.
Password for the private key stored in the PKCS#12 file.
Defaults to the same value as
(Secure) - Password for the private key stored in the PKCS#12 file.
- Path to the PKCS#12 file that holds the certificates to be trusted.
xpack.monitoring.exporters.$NAME.ssl.truststore.type
Set this to
PKCS12
to indicate that the truststore is a PKCS#12 file. -
