System Functionsedit
These functions return metadata type of information about the system being queried.
DATABASE
Synopsis:
DATABASE()
Input: none
Output: string
Description:Returns the name of the database being queried. In the case of Elasticsearch SQL, this is the name of the Elasticsearch cluster. This function should always return a non-null value.
SELECT DATABASE(); DATABASE --------------- elasticsearch
USER
Synopsis:
USER()
Input: none
Output: string
Description:Returns the username of the authenticated user executing the query. This function can
return null
in case security features are disabled.
SELECT USER(); USER --------------- elastic
