How monitoring worksedit
Each Elasticsearch node, Logstash node, Kibana instance, and Beat is considered unique in the
cluster based on its persistent UUID, which is written to the
path.data
directory when the node or instance starts.
Monitoring documents are just ordinary JSON documents built by monitoring each Elastic Stack component at a specified collection interval. If you want to alter the templates for these indices, see Configuring indices for monitoring.
Each component in the Elastic Stack is responsible for monitoring itself and then forwarding those documents to the production cluster for both routing and indexing (storage). The routing and indexing processes in Elasticsearch are handled by what are called collectors and exporters.
Alternatively, you can use Metricbeat to collect monitoring data and ship it directly to the monitoring cluster.
To learn how to collect monitoring data, see:
