Get rollup index capabilities APIedit
Returns the rollup capabilities of all jobs inside of a rollup index (e.g. the index where rollup data is stored).
Requestedit
GET <target>/_rollup/data
Prerequisitesedit
If the Elasticsearch security features are enabled, you must have any of the
read
,view_index_metadata
, ormanage
index privilege on the index that stores the rollup results. For more information, see Security privileges.
Descriptionedit
A single rollup index may store the data for multiple rollup jobs, and may have a variety of capabilities depending on those jobs.
This API will allow you to determine:
- What jobs are stored in an index (or indices specified via a pattern)?
- What target indices were rolled up, what fields were used in those rollups and what aggregations can be performed on each job?
Path parametersedit
<target>
(Required, string) Data stream or index to check for rollup capabilities.
Wildcard (
) expressions are supported.
Examplesedit
Imagine we have an index named sensor-1
full of raw data. We know that the
data will grow over time, so there will be a sensor-2
, sensor-3
, etc.
Let’s create a rollup job that stores its data in sensor_rollup
PUT _rollup/job/sensor { "index_pattern": "sensor-*", "rollup_index": "sensor_rollup", "cron": "*/30 * * * * ?", "page_size": 1000, "groups": { "date_histogram": { "field": "timestamp", "fixed_interval": "1h", "delay": "7d" }, "terms": { "fields": [ "node" ] } }, "metrics": [ { "field": "temperature", "metrics": [ "min", "max", "sum" ] }, { "field": "voltage", "metrics": [ "avg" ] } ] }
If at a later date, we’d like to determine what jobs and capabilities were
stored in the sensor_rollup
index, we can use the get rollup index API:
GET /sensor_rollup/_rollup/data
Note how we are requesting the concrete rollup index name (sensor_rollup
) as
the first part of the URL. This will yield the following response:
{ "sensor_rollup" : { "rollup_jobs" : [ { "job_id" : "sensor", "rollup_index" : "sensor_rollup", "index_pattern" : "sensor-*", "fields" : { "node" : [ { "agg" : "terms" } ], "temperature" : [ { "agg" : "min" }, { "agg" : "max" }, { "agg" : "sum" } ], "timestamp" : [ { "agg" : "date_histogram", "time_zone" : "UTC", "fixed_interval" : "1h", "delay": "7d" } ], "voltage" : [ { "agg" : "avg" } ] } } ] } }
The response that is returned contains information that is similar to the original rollup configuration, but formatted differently. First, there are some house-keeping details: the rollup job ID, the index that holds the rolled data, the index pattern that the job was targeting.
Next it shows a list of fields that contain data eligible for rollup searches.
Here we see four fields: node
, temperature
, timestamp
and voltage
. Each
of these fields list the aggregations that are possible. For example, you can
use a min, max, or sum aggregation on the temperature
field, but only a
date_histogram
on timestamp
Note that the rollup_jobs
element is an array; there can be multiple,
independent jobs configured for a single index or index pattern. Each of these
jobs may have different configurations, so the API returns a list of all the
various configurations available.
Like other APIs that interact with indices, you can specify index patterns instead of explicit indices:
GET /*_rollup/_rollup/data
