Index blocksedit
Index blocks limit the kind of operations that are available on a certain index. The blocks come in different flavours, allowing to block write, read, or metadata operations. The blocks can be set / removed using dynamic index settings, or can be added using a dedicated API, which also ensures for write blocks that, once successfully returning to the user, all shards of the index are properly accounting for the block, for example that all in-flight writes to an index have been completed after adding the write block.
Index block settingsedit
The following dynamic index settings determine the blocks present on an index:
index.blocks.read_only
Set to
true
to make the index and index metadata read only,false
to allow writes and metadata changes. -
index.blocks.read_only_allow_delete
Similar to
index.blocks.write
, except that you can delete the index when this block is in place. Do not set or remove this block yourself. The disk-based shard allocator sets and removes this block automatically according to the available disk space.Deleting documents from an index to release resources - rather than deleting the index itself - increases the index size temporarily, and therefore may not be possible when nodes are low on disk space. When
is set totrue
, deleting documents is not permitted. However, deleting the index entirely requires very little extra disk space and frees up the disk space consumed by the index almost immediately so this is still permitted.Elasticsearch adds the read-only-allow-delete index block automatically when the disk utilization exceeds the flood stage watermark, and removes this block automatically when the disk utilization falls under the high watermark. See Disk-based shard allocation for more information about watermarks, and Fix watermark errors for help with resolving watermark issues.
index.blocks.read
Set to
true
to disable read operations against the index. -
index.blocks.write
Set to
true
to disable data write operations against the index. Unlikeread_only
, this setting does not affect metadata. For instance, you can adjust the settings of an index with awrite
block, but you cannot adjust the settings of an index with aread_only
block. -
index.blocks.metadata
Set to
true
to disable index metadata reads and writes.
Add index block APIedit
Adds an index block to an index.
PUT /my-index-000001/_block/write
Requestedit
PUT /<index>/_block/<block>
Path parametersedit
<index>
(Optional, string) Comma-separated list or wildcard expression of index names used to limit the request.
By default, you must explicitly name the indices you are adding blocks to. To allow the adding of blocks to indices with
_all
, or other wildcard expressions, change theaction.destructive_requires_name
setting tofalse
. You can update this setting in theelasticsearch.yml
file or using the cluster update settings API. -
<block>
(Required, string) Block type to add to the index.
Valid values for
<block>
metadata
- Disable metadata changes, such as closing the index.
read
- Disable read operations.
read_only
- Disable write operations and metadata changes.
write
- Disable write operations. However, metadata changes are still allowed.
Query parametersedit
allow_no_indices
(Optional, Boolean) If
false
, the request returns an error if any wildcard expression, index alias, or_all
value targets only missing or closed indices. This behavior applies even if the request targets other open indices. For example, a request targetingfoo*,bar*
returns an error if an index starts withfoo
but no index starts withbar
.Defaults to
true
expand_wildcards
(Optional, string) Type of index that wildcard patterns can match. If the request can target data streams, this argument determines whether wildcard expressions match hidden data streams. Supports comma-separated values, such as
open,hidden
. Valid values are:-
all
- Match any data stream or index, including hidden ones.
open
- Match open, non-hidden indices. Also matches any non-hidden data stream.
closed
- Match closed, non-hidden indices. Also matches any non-hidden data stream. Data streams cannot be closed.
hidden
Match hidden data streams and hidden indices. Must be combined with
open
,closed
, or both. -
none
- Wildcard patterns are not accepted.
Defaults to
open
ignore_unavailable
false
, the request returns an error if it targets a missing or closed index. Defaults tofalse
master_timeout
(Optional, time units)
Period to wait for a connection to the master node. If no response is received
before the timeout expires, the request fails and returns an error. Defaults to
30s
timeout
Period to wait for a response. If no response is received before the timeout
30s
Examplesedit
The following example shows how to add an index block:
The API returns following response:
{ "acknowledged" : true, "shards_acknowledged" : true, "indices" : [ { "name" : "my-index-000001", "blocked" : true } ] }
