Tune for search speededit
Give memory to the filesystem cacheedit
Elasticsearch heavily relies on the filesystem cache in order to make search fast. In general, you should make sure that at least half the available memory goes to the filesystem cache so that Elasticsearch can keep hot regions of the index in physical memory.
Avoid page cache thrashing by using modest readahead values on Linuxedit
Search can cause a lot of randomized read I/O. When the underlying block device has a high readahead value, there may be a lot of unnecessary read I/O done, especially when files are accessed using memory mapping (see storage types).
Most Linux distributions use a sensible readahead value of 128KiB
for a
single plain device, however, when using software raid, LVM or dm-crypt the
resulting block device (backing Elasticsearch path.data)
may end up having a very large readahead value (in the range of several MiB).
This usually results in severe page (filesystem) cache thrashing adversely
affecting search (or update) performance.
You can check the current value in KiB
using
lsblk -o NAME,RA,MOUNTPOINT,TYPE,SIZE
Consult the documentation of your distribution on how to alter this value
(for example with a udev
rule to persist across reboots, or via
blockdev --setra
as a transient setting). We recommend a value of 128KiB
for readahead.
blockdev
expects values in 512 byte sectors whereas lsblk
reports
values in KiB
. As an example, to temporarily set readahead to 128KiB
for /dev/nvme0n1
, specify blockdev --setra 256 /dev/nvme0n1
Use faster hardwareedit
If your searches are I/O-bound, consider increasing the size of the filesystem cache (see above) or using faster storage. Each search involves a mix of sequential and random reads across multiple files, and there may be many searches running concurrently on each shard, so SSD drives tend to perform better than spinning disks.
Directly-attached (local) storage generally performs better than remote storage because it is simpler to configure well and avoids communications overheads. With careful tuning it is sometimes possible to achieve acceptable performance using remote storage too. Benchmark your system with a realistic workload to determine the effects of any tuning parameters. If you cannot achieve the performance you expect, work with the vendor of your storage system to identify the problem.
If your searches are CPU-bound, consider using a larger number of faster CPUs.
Document modelingedit
Documents should be modeled so that search-time operations are as cheap as possible.
In particular, joins should be avoided. nested
can make queries
several times slower and parent-child relations can make
queries hundreds of times slower. So if the same questions can be answered without
joins by denormalizing documents, significant speedups can be expected.
Search as few fields as possibleedit
The more fields a query_string
or
multi_match
query targets, the slower it is.
A common technique to improve search speed over multiple fields is to copy
their values into a single field at index time, and then use this field at
search time. This can be automated with the copy-to
directive of
mappings without having to change the source of documents. Here is an example
of an index containing movies that optimizes queries that search over both the
name and the plot of the movie by indexing both values into the name_and_plot
field.
response = client.indices.create( index: 'movies', body: { mappings: { properties: { name_and_plot: { type: 'text' }, name: { type: 'text', copy_to: 'name_and_plot' }, plot: { type: 'text', copy_to: 'name_and_plot' } } } } ) puts response
PUT movies { "mappings": { "properties": { "name_and_plot": { "type": "text" }, "name": { "type": "text", "copy_to": "name_and_plot" }, "plot": { "type": "text", "copy_to": "name_and_plot" } } } }
Pre-index dataedit
You should leverage patterns in your queries to optimize the way data is indexed.
For instance, if all your documents have a price
field and most queries run
range
aggregations on a fixed
list of ranges, you could make this aggregation faster by pre-indexing the ranges
into the index and using a terms
aggregations.
For instance, if documents look like:
response = client.index( index: 'index', id: 1, body: { designation: 'spoon', price: 13 } ) puts response
PUT index/_doc/1 { "designation": "spoon", "price": 13 }
and search requests look like:
response = client.search( index: 'index', body: { aggregations: { price_ranges: { range: { field: 'price', ranges: [ { to: 10 }, { from: 10, to: 100 }, { from: 100 } ] } } } } ) puts response
GET index/_search { "aggs": { "price_ranges": { "range": { "field": "price", "ranges": [ { "to": 10 }, { "from": 10, "to": 100 }, { "from": 100 } ] } } } }
Then documents could be enriched by a price_range
field at index time, which
should be mapped as a keyword
response = client.indices.create( index: 'index', body: { mappings: { properties: { price_range: { type: 'keyword' } } } } ) puts response response = client.index( index: 'index', id: 1, body: { designation: 'spoon', price: 13, price_range: '10-100' } ) puts response
PUT index { "mappings": { "properties": { "price_range": { "type": "keyword" } } } } PUT index/_doc/1 { "designation": "spoon", "price": 13, "price_range": "10-100" }
And then search requests could aggregate this new field rather than running a
range
aggregation on the price
field.
response = client.search( index: 'index', body: { aggregations: { price_ranges: { terms: { field: 'price_range' } } } } ) puts response
GET index/_search { "aggs": { "price_ranges": { "terms": { "field": "price_range" } } } }
Consider mapping identifiers as keyword
Not all numeric data should be mapped as a numeric field data type.
Elasticsearch optimizes numeric fields, such as integer
or long
, for
range
queries. However, keyword
fields
are better for term
and other
term-level queries.
Identifiers, such as an ISBN or a product ID, are rarely used in range
queries. However, they are often retrieved using term-level queries.
Consider mapping a numeric identifier as a keyword
if:
You don’t plan to search for the identifier data using
range
queries. -
Fast retrieval is important.
term
query searches onkeyword
fields are often faster thanterm
searches on numeric fields.
If you’re unsure which to use, you can use a multi-field to map
the data as both a keyword
and a numeric data type.
Avoid scriptsedit
If possible, avoid using script-based sorting, scripts in
aggregations, and the script_score
query. See
Scripts, caching, and search speed.
Search rounded datesedit
Queries on date fields that use now
are typically not cacheable since the
range that is being matched changes all the time. However switching to a
rounded date is often acceptable in terms of user experience, and has the
benefit of making better use of the query cache.
For instance the below query:
response = client.index( index: 'index', id: 1, body: { my_date: '2016-05-11T16:30:55.328Z' } ) puts response response = client.search( index: 'index', body: { query: { constant_score: { filter: { range: { my_date: { gte: 'now-1h', lte: 'now' } } } } } } ) puts response
PUT index/_doc/1 { "my_date": "2016-05-11T16:30:55.328Z" } GET index/_search { "query": { "constant_score": { "filter": { "range": { "my_date": { "gte": "now-1h", "lte": "now" } } } } } }
could be replaced with the following query:
response = client.search( index: 'index', body: { query: { constant_score: { filter: { range: { my_date: { gte: 'now-1h/m', lte: 'now/m' } } } } } } ) puts response
GET index/_search { "query": { "constant_score": { "filter": { "range": { "my_date": { "gte": "now-1h/m", "lte": "now/m" } } } } } }
In that case we rounded to the minute, so if the current time is 16:31:29
the range query will match everything whose value of the my_date
field is
between 15:31:00
and 16:31:59
. And if several users run a query that
contains this range in the same minute, the query cache could help speed things
up a bit. The longer the interval that is used for rounding, the more the query
cache can help, but beware that too aggressive rounding might also hurt user
experience.
It might be tempting to split ranges into a large cacheable part and smaller not cacheable parts in order to be able to leverage the query cache, as shown below:
response = client.search( index: 'index', body: { query: { constant_score: { filter: { bool: { should: [ { range: { my_date: { gte: 'now-1h', lte: 'now-1h/m' } } }, { range: { my_date: { gt: 'now-1h/m', lt: 'now/m' } } }, { range: { my_date: { gte: 'now/m', lte: 'now' } } } ] } } } } } ) puts response
GET index/_search { "query": { "constant_score": { "filter": { "bool": { "should": [ { "range": { "my_date": { "gte": "now-1h", "lte": "now-1h/m" } } }, { "range": { "my_date": { "gt": "now-1h/m", "lt": "now/m" } } }, { "range": { "my_date": { "gte": "now/m", "lte": "now" } } } ] } } } } }
However such practice might make the query run slower in some cases since the
overhead introduced by the bool
query may defeat the savings from better
leveraging the query cache.
Force-merge read-only indicesedit
Indices that are read-only may benefit from being merged down to a single segment. This is typically the case with time-based indices: only the index for the current time frame is getting new documents while older indices are read-only. Shards that have been force-merged into a single segment can use simpler and more efficient data structures to perform searches.
Do not force-merge indices to which you are still writing, or to which you will write again in the future. Instead, rely on the automatic background merge process to perform merges as needed to keep the index running smoothly. If you continue to write to a force-merged index then its performance may become much worse.
Warm up global ordinalsedit
Global ordinals are a data structure that is used to optimize the performance of aggregations. They are calculated lazily and stored in the JVM heap as part of the field data cache. For fields that are heavily used for bucketing aggregations, you can tell Elasticsearch to construct and cache the global ordinals before requests are received. This should be done carefully because it will increase heap usage and can make refreshes take longer. The option can be updated dynamically on an existing mapping by setting the eager global ordinals mapping parameter:
response = client.indices.create( index: 'index', body: { mappings: { properties: { foo: { type: 'keyword', eager_global_ordinals: true } } } } ) puts response
PUT index { "mappings": { "properties": { "foo": { "type": "keyword", "eager_global_ordinals": true } } } }
Warm up the filesystem cacheedit
If the machine running Elasticsearch is restarted, the filesystem cache will be
empty, so it will take some time before the operating system loads hot regions
of the index into memory so that search operations are fast. You can explicitly
tell the operating system which files should be loaded into memory eagerly
depending on the file extension using the
index.store.preload
setting.
Loading data into the filesystem cache eagerly on too many indices or too many files will make search slower if the filesystem cache is not large enough to hold all the data. Use with caution.
Use index sorting to speed up conjunctionsedit
Index sorting can be useful in order to make conjunctions faster at the cost of slightly slower indexing. Read more about it in the index sorting documentation.
Use preference
to optimize cache utilizationedit
There are multiple caches that can help with search performance, such as the filesystem cache, the request cache or the query cache. Yet all these caches are maintained at the node level, meaning that if you run the same request twice in a row, have 1 replica or more and use round-robin, the default routing algorithm, then those two requests will go to different shard copies, preventing node-level caches from helping.
Since it is common for users of a search application to run similar requests one after another, for instance in order to analyze a narrower subset of the index, using a preference value that identifies the current user or session could help optimize usage of the caches.
Replicas might help with throughput, but not alwaysedit
In addition to improving resiliency, replicas can help improve throughput. For instance if you have a single-shard index and three nodes, you will need to set the number of replicas to 2 in order to have 3 copies of your shard in total so that all nodes are utilized.
Now imagine that you have a 2-shards index and two nodes. In one case, the number of replicas is 0, meaning that each node holds a single shard. In the second case the number of replicas is 1, meaning that each node has two shards. Which setup is going to perform best in terms of search performance? Usually, the setup that has fewer shards per node in total will perform better. The reason for that is that it gives a greater share of the available filesystem cache to each shard, and the filesystem cache is probably Elasticsearch’s number 1 performance factor. At the same time, beware that a setup that does not have replicas is subject to failure in case of a single node failure, so there is a trade-off between throughput and availability.
So what is the right number of replicas? If you have a cluster that has
num_nodes
nodes, num_primaries
primary shards in total and if you want to
be able to cope with max_failures
node failures at once at most, then the
right number of replicas for you is
max(max_failures, ceil(num_nodes / num_primaries) - 1)
Tune your queries with the Search Profileredit
The Profile API provides detailed information about how each component of your queries and aggregations impacts the time it takes to process the request.
The Search Profiler in Kibana makes it easy to navigate and analyze the profile results and give you insight into how to tune your queries to improve performance and reduce load.
Because the Profile API itself adds significant overhead to the query, this information is best used to understand the relative cost of the various query components. It does not provide a reliable measure of actual processing time.
Faster phrase queries with index_phrases
The text
field has an index_phrases
option that
indexes 2-shingles and is automatically leveraged by query parsers to run phrase
queries that don’t have a slop. If your use-case involves running lots of phrase
queries, this can speed up queries significantly.
Faster prefix queries with index_prefixes
The text
field has an index_prefixes
option that
indexes prefixes of all terms and is automatically leveraged by query parsers to
run prefix queries. If your use-case involves running lots of prefix queries,
Use constant_keyword
to speed up filteringedit
There is a general rule that the cost of a filter is mostly a function of the
number of matched documents. Imagine that you have an index containing cycles.
There are a large number of bicycles and many searches perform a filter on
cycle_type: bicycle
. This very common filter is unfortunately also very costly
since it matches most documents. There is a simple way to avoid running this
filter: move bicycles to their own index and filter bicycles by searching this
index instead of adding a filter to the query.
Unfortunately this can make client-side logic tricky, which is where
constant_keyword
helps. By mapping cycle_type
as a constant_keyword
with
value bicycle
on the index that contains bicycles, clients can keep running
the exact same queries as they used to run on the monolithic index and
Elasticsearch will do the right thing on the bicycles index by ignoring filters
on cycle_type
if the value is bicycle
and returning no hits otherwise.
Here is what mappings could look like:
response = client.indices.create( index: 'bicycles', body: { mappings: { properties: { cycle_type: { type: 'constant_keyword', value: 'bicycle' }, name: { type: 'text' } } } } ) puts response response = client.indices.create( index: 'other_cycles', body: { mappings: { properties: { cycle_type: { type: 'keyword' }, name: { type: 'text' } } } } ) puts response
PUT bicycles { "mappings": { "properties": { "cycle_type": { "type": "constant_keyword", "value": "bicycle" }, "name": { "type": "text" } } } } PUT other_cycles { "mappings": { "properties": { "cycle_type": { "type": "keyword" }, "name": { "type": "text" } } } }
We are splitting our index in two: one that will contain only bicycles, and another one that contains other cycles: unicycles, tricycles, etc. Then at search time, we need to search both indices, but we don’t need to modify queries.
response = client.search( index: 'bicycles,other_cycles', body: { query: { bool: { must: { match: { description: 'dutch' } }, filter: { term: { cycle_type: 'bicycle' } } } } } ) puts response
GET bicycles,other_cycles/_search { "query": { "bool": { "must": { "match": { "description": "dutch" } }, "filter": { "term": { "cycle_type": "bicycle" } } } } }
On the bicycles
index, Elasticsearch will simply ignore the cycle_type
filter and rewrite the search request to the one below:
response = client.search( index: 'bicycles,other_cycles', body: { query: { match: { description: 'dutch' } } } ) puts response
GET bicycles,other_cycles/_search { "query": { "match": { "description": "dutch" } } }
On the other_cycles
index, Elasticsearch will quickly figure out that
bicycle
doesn’t exist in the terms dictionary of the cycle_type
field and
return a search response with no hits.
This is a powerful way of making queries cheaper by putting common values in a
dedicated index. This idea can also be combined across multiple fields: for
instance if you track the color of each cycle and your bicycles
index ends up
having a majority of black bikes, you could split it into a bicycles-black
and a bicycles-other-colors
indices.
The constant_keyword
is not strictly required for this optimization: it is
also possible to update the client-side logic in order to route queries to the
relevant indices based on filters. However constant_keyword
makes it
transparently and allows to decouple search requests from the index topology in
exchange of very little overhead.
