Multi-target syntaxedit
Most APIs that accept a <data-stream>
, <index>
, or <target>
request path
parameter also support multi-target syntax.
In multi-target syntax, you can use a comma-separated list to run a request on
multiple resources, such as data streams, indices, or index aliases:
test1,test2,test3
. You can also use glob-like
wildcard (*
) expressions to target resources that match a pattern: test*
or
*test
or te*t
or *test*
You can exclude targets using the -
character: test*,-test3
Index aliases are resolved after wildcard expressions. This can
result in a request that targets an excluded alias. For example, if test3
is
an index alias, the pattern test*,-test3
still targets the indices for
test3
. To avoid this, exclude the concrete indices for the alias instead.
Multi-target APIs that can target indices support the following query string parameters:
ignore_unavailable
(Optional, Boolean) If
false
, the request returns an error if it targets a missing or closed index. Defaults tofalse
allow_no_indices
false
, the request returns an error when a wildcard expression, index alias, or_all
value targets only missing or closed indices. -
expand_wildcards
(Optional, string) Controls what kind of indices that wildcard expressions can expand to. Multiple values are accepted when separated by a comma, as in
open,hidden
. Valid values are:-
all
- Expand to open and closed indices, including hidden indices.
open
- Expand only to open indices.
closed
- Expand only to closed indices.
hidden
Expansion of wildcards will include hidden indices.
Must be combined with
open
,closed
, or both. -
none
- Wildcard expressions are not accepted.
The defaults settings for the above parameters depend on the API being used.
Some multi-target APIs that can target indices also support the following query string parameter:
ignore_throttled
true
, concrete, expanded or aliased indices are ignored when frozen. Defaults totrue
Single index APIs, such as the Document APIs and
single-index alias
APIs, do not support multi-target
syntax.
