Tune for search speededit
Give memory to the filesystem cacheedit
Elasticsearch heavily relies on the filesystem cache in order to make search fast. In general, you should make sure that at least half the available memory goes to the filesystem cache so that Elasticsearch can keep hot regions of the index in physical memory.
Avoid page cache thrashing by using modest readahead values on Linuxedit
Search can cause a lot of randomized read I/O. When the underlying block device has a high readahead value, there may be a lot of unnecessary read I/O done, especially when files are accessed using memory mapping (see storage types).
Most Linux distributions use a sensible readahead value of 128KiB
for a
single plain device, however, when using software raid, LVM or dm-crypt the
resulting block device (backing Elasticsearch path.data)
may end up having a very large readahead value (in the range of several MiB).
This usually results in severe page (filesystem) cache thrashing adversely
affecting search (or update) performance.
You can check the current value in KiB
using
lsblk -o NAME,RA,MOUNTPOINT,TYPE,SIZE
Consult the documentation of your distribution on how to alter this value
(for example with a udev
rule to persist across reboots, or via
blockdev --setra
as a transient setting). We recommend a value of 128KiB
for readahead.
blockdev
expects values in 512 byte sectors whereas lsblk
reports
values in KiB
. As an example, to temporarily set readahead to 128KiB
for /dev/nvme0n1
, specify blockdev --setra 256 /dev/nvme0n1
Use faster hardwareedit
If your search is I/O bound, you should investigate giving more memory to the
filesystem cache (see above) or buying faster drives. In particular SSD drives
are known to perform better than spinning disks. Always use local storage,
remote filesystems such as NFS
or SMB
should be avoided. Also beware of
virtualized storage such as Amazon’s Elastic Block Storage
. Virtualized
storage works very well with Elasticsearch, and it is appealing since it is so
fast and simple to set up, but it is also unfortunately inherently slower on an
ongoing basis when compared to dedicated local storage. If you put an index on
EBS
, be sure to use provisioned IOPS otherwise operations could be quickly
throttled.
If your search is CPU-bound, you should investigate buying faster CPUs.
Document modelingedit
Documents should be modeled so that search-time operations are as cheap as possible.
In particular, joins should be avoided. nested
can make queries
several times slower and parent-child relations can make
queries hundreds of times slower. So if the same questions can be answered without
joins by denormalizing documents, significant speedups can be expected.
Search as few fields as possibleedit
The more fields a query_string
or
multi_match
query targets, the slower it is.
A common technique to improve search speed over multiple fields is to copy
their values into a single field at index time, and then use this field at
search time. This can be automated with the copy-to
directive of
mappings without having to change the source of documents. Here is an example
of an index containing movies that optimizes queries that search over both the
name and the plot of the movie by indexing both values into the name_and_plot
field.
PUT movies { "mappings": { "properties": { "name_and_plot": { "type": "text" }, "name": { "type": "text", "copy_to": "name_and_plot" }, "plot": { "type": "text", "copy_to": "name_and_plot" } } } }
Pre-index dataedit
You should leverage patterns in your queries to optimize the way data is indexed.
For instance, if all your documents have a price
field and most queries run
range
aggregations on a fixed
list of ranges, you could make this aggregation faster by pre-indexing the ranges
into the index and using a terms
aggregations.
For instance, if documents look like:
PUT index/_doc/1 { "designation": "spoon", "price": 13 }
and search requests look like:
GET index/_search { "aggs": { "price_ranges": { "range": { "field": "price", "ranges": [ { "to": 10 }, { "from": 10, "to": 100 }, { "from": 100 } ] } } } }
Then documents could be enriched by a price_range
field at index time, which
should be mapped as a keyword
PUT index { "mappings": { "properties": { "price_range": { "type": "keyword" } } } } PUT index/_doc/1 { "designation": "spoon", "price": 13, "price_range": "10-100" }
And then search requests could aggregate this new field rather than running a
range
aggregation on the price
field.
GET index/_search { "aggs": { "price_ranges": { "terms": { "field": "price_range" } } } }
Consider mapping identifiers as keyword
Not all numeric data should be mapped as a numeric field data type.
Elasticsearch optimizes numeric fields, such as integer
or long
, for
range
queries. However, keyword
fields
are better for term
and other
term-level queries.
Identifiers, such as an ISBN or a product ID, are rarely used in range
queries. However, they are often retrieved using term-level queries.
Consider mapping a numeric identifier as a keyword
if:
You don’t plan to search for the identifier data using
range
queries. -
Fast retrieval is important.
term
query searches onkeyword
fields are often faster thanterm
searches on numeric fields.
If you’re unsure which to use, you can use a multi-field to map
the data as both a keyword
and a numeric data type.
Avoid scriptsedit
If possible, avoid using script-based sorting, scripts in
aggregations, and the script_score
query. See
Scripts, caching, and search speed.
Search rounded datesedit
Queries on date fields that use now
are typically not cacheable since the
range that is being matched changes all the time. However switching to a
rounded date is often acceptable in terms of user experience, and has the
benefit of making better use of the query cache.
For instance the below query:
PUT index/_doc/1 { "my_date": "2016-05-11T16:30:55.328Z" } GET index/_search { "query": { "constant_score": { "filter": { "range": { "my_date": { "gte": "now-1h", "lte": "now" } } } } } }
could be replaced with the following query:
GET index/_search { "query": { "constant_score": { "filter": { "range": { "my_date": { "gte": "now-1h/m", "lte": "now/m" } } } } } }
In that case we rounded to the minute, so if the current time is 16:31:29
the range query will match everything whose value of the my_date
field is
between 15:31:00
and 16:31:59
. And if several users run a query that
contains this range in the same minute, the query cache could help speed things
up a bit. The longer the interval that is used for rounding, the more the query
cache can help, but beware that too aggressive rounding might also hurt user
experience.
It might be tempting to split ranges into a large cacheable part and smaller not cacheable parts in order to be able to leverage the query cache, as shown below:
GET index/_search { "query": { "constant_score": { "filter": { "bool": { "should": [ { "range": { "my_date": { "gte": "now-1h", "lte": "now-1h/m" } } }, { "range": { "my_date": { "gt": "now-1h/m", "lt": "now/m" } } }, { "range": { "my_date": { "gte": "now/m", "lte": "now" } } } ] } } } } }
However such practice might make the query run slower in some cases since the
overhead introduced by the bool
query may defeat the savings from better
leveraging the query cache.
Force-merge read-only indicesedit
Indices that are read-only may benefit from being merged down to a single segment. This is typically the case with time-based indices: only the index for the current time frame is getting new documents while older indices are read-only. Shards that have been force-merged into a single segment can use simpler and more efficient data structures to perform searches.
Do not force-merge indices to which you are still writing, or to which you will write again in the future. Instead, rely on the automatic background merge process to perform merges as needed to keep the index running smoothly. If you continue to write to a force-merged index then its performance may become much worse.
Warm up global ordinalsedit
Global ordinals are a data structure that is used to optimize the performance of aggregations. They are calculated lazily and stored in the JVM heap as part of the field data cache. For fields that are heavily used for bucketing aggregations, you can tell Elasticsearch to construct and cache the global ordinals before requests are received. This should be done carefully because it will increase heap usage and can make refreshes take longer. The option can be updated dynamically on an existing mapping by setting the eager global ordinals mapping parameter:
PUT index { "mappings": { "properties": { "foo": { "type": "keyword", "eager_global_ordinals": true } } } }
Warm up the filesystem cacheedit
If the machine running Elasticsearch is restarted, the filesystem cache will be
empty, so it will take some time before the operating system loads hot regions
of the index into memory so that search operations are fast. You can explicitly
tell the operating system which files should be loaded into memory eagerly
depending on the file extension using the
index.store.preload
setting.
Loading data into the filesystem cache eagerly on too many indices or too many files will make search slower if the filesystem cache is not large enough to hold all the data. Use with caution.
Use index sorting to speed up conjunctionsedit
Index sorting can be useful in order to make conjunctions faster at the cost of slightly slower indexing. Read more about it in the index sorting documentation.
Use preference
to optimize cache utilizationedit
There are multiple caches that can help with search performance, such as the filesystem cache, the request cache or the query cache. Yet all these caches are maintained at the node level, meaning that if you run the same request twice in a row, have 1 replica or more and use round-robin, the default routing algorithm, then those two requests will go to different shard copies, preventing node-level caches from helping.
Since it is common for users of a search application to run similar requests one after another, for instance in order to analyze a narrower subset of the index, using a preference value that identifies the current user or session could help optimize usage of the caches.
Replicas might help with throughput, but not alwaysedit
In addition to improving resiliency, replicas can help improve throughput. For instance if you have a single-shard index and three nodes, you will need to set the number of replicas to 2 in order to have 3 copies of your shard in total so that all nodes are utilized.
Now imagine that you have a 2-shards index and two nodes. In one case, the number of replicas is 0, meaning that each node holds a single shard. In the second case the number of replicas is 1, meaning that each node has two shards. Which setup is going to perform best in terms of search performance? Usually, the setup that has fewer shards per node in total will perform better. The reason for that is that it gives a greater share of the available filesystem cache to each shard, and the filesystem cache is probably Elasticsearch’s number 1 performance factor. At the same time, beware that a setup that does not have replicas is subject to failure in case of a single node failure, so there is a trade-off between throughput and availability.
So what is the right number of replicas? If you have a cluster that has
num_nodes
nodes, num_primaries
primary shards in total and if you want to
be able to cope with max_failures
node failures at once at most, then the
right number of replicas for you is
max(max_failures, ceil(num_nodes / num_primaries) - 1)
