WARNING: Version 5.5 of Elasticsearch has passed its EOL date.
Node level settings related to shadow replicasedit
These are non-dynamic settings that need to be configured in elasticsearch.yml
node.add_lock_id_to_custom_path
Boolean setting indicating whether Elasticsearch should append the node’s
ordinal to the custom data path. For example, if this is enabled and a path
of "/tmp/foo" is used, the first locally-running node will use "/tmp/foo/0",
the second will use "/tmp/foo/1", the third "/tmp/foo/2", etc. Defaults to
true
