WARNING: Version 2.3 of Elasticsearch has passed its EOL date.
boost
Individual fields can be boosted — count more towards the relevance score — at index time, with the boost
parameter as follows:
PUT my_index { "mappings": { "my_type": { "properties": { "title": { "type": "string", "boost": 2 }, "content": { "type": "string" } } } } }
Matches on the |
Note that a title
field will usually be shorter than a content
field. The
default relevance calculation takes field length into account, so a short
title
field will have a higher natural boost than a long content
field.
Why index time boosting is a bad idea
We advise against using index time boosting for the following reasons:
You cannot change index-time
boost
values without reindexing all of your documents. -
Every query supports query-time boosting which achieves the same effect. The
difference is that you can tweak the
boost
value without having to reindex. -
Index-time boosts are stored as part of the
norm
, which is only one byte. This reduces the resolution of the field length normalization factor which can lead to lower quality relevance calculations.
The only advantage that index time boosting has is that it is copied with the
value into the _all
field. This means that, when
querying the _all
field, words that originated from the title
field will
have a higher score than words that originated in the content
field.
This functionality comes at a cost: queries on the _all
field are slower
when index-time boosting is used.
