URI parts processor
editURI parts processor
Table 43. URI Parts Options
| Name | Required | Default | Description |
yes |
no |
no |
true |
If |
no |
false |
If |
no |
no |
no |
no |
no |
"description" : "...",
"processors" : [
"uri_parts": {
"field": "input_field",
"target_field": "url",
"keep_original": true,
"remove_if_successful": false
"_source": {
"input_field": "http://myusername:mypassword@www.example.com:80/foo.gif?key1=val1&key2=val2#fragment"
It produces this result:
"_source" : {
"input_field" : "http://myusername:mypassword@www.example.com:80/foo.gif?key1=val1&key2=val2#fragment",
"url" : {
"path" : "/foo.gif",
"fragment" : "fragment",
"extension" : "gif",
"password" : "mypassword",
"original" : "http://myusername:mypassword@www.example.com:80/foo.gif?key1=val1&key2=val2#fragment",
"scheme" : "http",
"port" : 80,
"user_info" : "myusername:mypassword",
"domain" : "www.example.com",
"query" : "key1=val1&key2=val2",
"username" : "myusername"
