URI parts processoredit
Parses a Uniform Resource Identifier (URI) string and extracts its components as an object. This URI object includes properties for the URI’s domain, path, fragment, port, query, scheme, user info, username, and password.
Table 44. URI Parts Options
Name Required Default Description
field
yes
Field containing the URI string.
target_field
no
url
Output field for the URI object.
keep_original
no
true
If true, the processor copies the unparsed URI to <target_field>.original.
remove_if_successful
no
false
If true, the processor removes the field after parsing the URI string. If parsing fails, the processor does not remove the field.
description
no
Description of the processor. Useful for describing the purpose of the processor or its configuration.
if
no
Conditionally execute the processor. See Handling pipeline failures.
ignore_failure
no
false
Ignore failures for the processor. See Handling failures in pipelines.
on_failure
no
Handle failures for the processor. See Handling failures in pipelines.
tag
no
Identifier for the processor. Useful for debugging and metrics.
  "description" : "...",
  "processors" : [
      "uri_parts": {
        "field": "input_field",
        "target_field": "url",
        "keep_original": true,
        "remove_if_successful": false
  "_source": {
    "input_field": "http://myusername:mypassword@www.example.com:80/foo.gif?key1=val1&key2=val2#fragment"
It produces this result:
"_source" : {
  "input_field" : "http://myusername:mypassword@www.example.com:80/foo.gif?key1=val1&key2=val2#fragment",
  "url" : {
    "path" : "/foo.gif",
    "fragment" : "fragment",
    "extension" : "gif",
    "password" : "mypassword",
    "original" : "http://myusername:mypassword@www.example.com:80/foo.gif?key1=val1&key2=val2#fragment",
    "scheme" : "http",
    "port" : 80,
    "user_info" : "myusername:mypassword",
    "domain" : "www.example.com",
    "query" : "key1=val1&key2=val2",
    "username" : "myusername"
