Logstash connection doesn’t workedit
You may have configured Logstash or Metricbeat incorrectly. To resolve the issue:
  • Make sure that Logstash is running and you can connect to it. First, try to ping the Logstash host to verify that you can reach it from the host running Metricbeat. Then use either nc or telnet to make sure that the port is available. For example:
    ping <hostname or IP>
    telnet <hostname or IP> 5044
  • Verify that the config file for Metricbeat specifies the correct port where Logstash is running.
  • Make sure that the Elasticsearch output is commented out in the config file and the Logstash output is uncommented.
  • Confirm that the most recent Beats input plugin for Logstash is installed and configured. Note that Beats will not connect to the Lumberjack input plugin. To learn how to install and update plugins, see Working with plugins.
