A newer version is available. For the latest information, see the
Remote cluster info APIedit
Returns configured remote cluster information.
Requestedit
GET /_remote/info
Prerequisitesedit
If the Elasticsearch security features are enabled, you must have the
monitor
ormanage
cluster privilege to use this API.
Descriptionedit
The cluster remote info API allows you to retrieve all of the configured remote cluster information. It returns connection and endpoint information keyed by the configured remote cluster alias.
Response bodyedit
mode
Connection mode for the remote cluster. Returned values are
sniff
andproxy
connected
- True if there is at least one connection to the remote cluster.
initial_connect_timeout
- The initial connect timeout for remote cluster connections.
skip_unavailable
Whether a cross-cluster search skips the remote cluster if its nodes are unavailable during the
search. If
true
, a cross-cluster search also ignores errors returned by the remote cluster. Refer to Optional remote clusters. -
seeds
- Initial seed transport addresses of the remote cluster when sniff mode is configured.
num_nodes_connected
- Number of connected nodes in the remote cluster when sniff mode is configured.
max_connections_per_cluster
- Maximum number of connections maintained for the remote cluster when sniff mode is configured.
proxy_address
- Address for remote connections when proxy mode is configured.
num_proxy_sockets_connected
- Number of open socket connections to the remote cluster when proxy mode is configured.
max_proxy_socket_connections
- The maximum number of socket connections to the remote cluster when proxy mode is configured.
