WARNING: Version 0.90 of Elasticsearch has passed its EOL date.
Mapperedit
The mapper module acts as a registry for the type mapping definitions added to an index either when creating it or by using the put mapping api. It also handles the dynamic mapping support for types that have no explicit mappings pre defined. For more information about mapping definitions, check out the mapping section.
Dynamic / Default Mappingsedit
Dynamic mappings allow to automatically apply generic mapping definition
to types that do not have mapping pre defined or applied to new mapping
definitions (overridden). This is mainly done thanks to the fact that
the object
type and namely the root object
type allow for schema
less dynamic addition of unmapped fields.
The default mapping definition is plain mapping definition that is embedded within ElasticSearch:
{ _default_ : { } }
Pretty short, no? Basically, everything is defaulted, especially the
dynamic nature of the root object mapping. The default mapping
definition can be overridden in several manners. The simplest manner is
to simply define a file called default-mapping.json
and placed it
under the config
directory (which can be configured to exist in a
different location). It can also be explicitly set using the
index.mapper.default_mapping_location
setting.
Dynamic creation of mappings for unmapped types can be completely
disabled by setting index.mapper.dynamic
to false
