Multiple Indicesedit
Most APIs that refer to an index
parameter support execution across multiple indices,
using simple test1,test2,test3
notation (or _all
for all indices). It also
supports wildcards, for example: test*
or *test
or te*t
or *test*
, and the
ability to "exclude" (-
), for example: test*,-test3
All multi index APIs support the following url query string parameters:
ignore_unavailable
(Optional, boolean) If
true
, missing or closed indices are not included in the response. Defaults tofalse
allow_no_indices
true
, the request does not return an error if a wildcard expression or_all
value retrieves only missing or closed indices.This parameter also applies to index aliases that point to a missing or closed index.
expand_wildcards
(Optional, string) Controls what kind of indices that wildcard expressions can expand to. Valid values are:
all
- Expand to open and closed indices.
open
- Expand only to open indices.
closed
- Expand only to closed indices.
none
- Wildcard expressions are not accepted.
The defaults settings for the above parameters depend on the API being used.
Single index APIs such as the Document APIs and the
single-index alias
APIs do not support multiple indices.
