Aggregate metric field typeedit
Stores pre-aggregated numeric values for metric
aggregations. An aggregate_metric_double
field is an object containing one
or more of the following metric sub-fields: min
, max
, sum
, and
value_count
When you run certain metric aggregations on an aggregate_metric_double
field,
the aggregation uses the related sub-field’s values. For example, a
min
aggregation on an
field returns the minimum value of all min
sub-fields.
field stores a single numeric
doc value for each metric sub-field. Array values are not
supported. min
, max
, and sum
values are double
numbers. value_count
is a positive long
number.
PUT my-index { "mappings": { "properties": { "my-agg-metric-field": { "type": "aggregate_metric_double", "metrics": [ "min", "max", "sum", "value_count" ], "default_metric": "max" } } } }
Parameters for aggregate_metric_double
fieldsedit
metrics
(Required, array of strings)
Array of metric sub-fields to store. Each value corresponds to a
metric aggregation. Valid values are
min
,max
,sum
, andvalue_count
. You must specify at least one value. -
default_metric
(Required, string)
Default metric sub-field to use for queries, scripts, and aggregations that
don’t use a sub-field. Must be a value from the
metrics
array. -
time_series_metric
[preview] This functionality is in technical preview and may be changed or removed in a future release. Elastic will work to fix any issues, but features in technical preview are not subject to the support SLA of official GA features. (Optional, string)
For internal use by Elastic only.
Marks the field as a time series metric. The value is the metric type. Defaults to
null
(Not a time series metric).For
fields, this parameter acceptscounter
,gauge
, andsummary
. You can’t update this parameter for existing fields.
Usesedit
We designed aggregate_metric_double
fields for use with the following aggregations:
A
min
aggregation returns the minimum value of allmin
sub-fields. -
A
max
aggregation returns the maximum value of allmax
sub-fields. -
A
sum
aggregation returns the sum of the values of allsum
sub-fields. -
A
value_count
aggregation returns the sum of the values of allvalue_count
sub-fields. -
A
avg
aggregation. There is noavg
sub-field; the result of theavg
aggregation is computed using thesum
andvalue_count
metrics. To run anavg
aggregation, the field must contain bothsum
andvalue_count
metric sub-field.
Running any other aggregation on an aggregate_metric_double
field will fail with
an "unsupported aggregation" error.
Finally, an aggregate_metric_double
field supports the following queries for which
it behaves as a double
by delegating its behavior to its default_metric
sub-field:
Examplesedit
The following create index API request creates an
index with an aggregate_metric_double
field named agg_metric
. The request
sets max
as the field’s default_metric
PUT stats-index { "mappings": { "properties": { "agg_metric": { "type": "aggregate_metric_double", "metrics": [ "min", "max", "sum", "value_count" ], "default_metric": "max" } } } }
The following index API request adds documents with
pre-aggregated data in the agg_metric
field.
PUT stats-index/_doc/1 { "agg_metric": { "min": -302.50, "max": 702.30, "sum": 200.0, "value_count": 25 } } PUT stats-index/_doc/2 { "agg_metric": { "min": -93.00, "max": 1702.30, "sum": 300.00, "value_count": 25 } }
You can run min
, max
, sum
, value_count
, and avg
aggregations on a
agg_metric
field.
POST stats-index/_search?size=0 { "aggs": { "metric_min": { "min": { "field": "agg_metric" } }, "metric_max": { "max": { "field": "agg_metric" } }, "metric_value_count": { "value_count": { "field": "agg_metric" } }, "metric_sum": { "sum": { "field": "agg_metric" } }, "metric_avg": { "avg": { "field": "agg_metric" } } } }
The aggregation results are based on related metric sub-field values.
{ ... "aggregations": { "metric_min": { "value": -302.5 }, "metric_max": { "value": 1702.3 }, "metric_value_count": { "value": 50 }, "metric_sum": { "value": 500.0 }, "metric_avg": { "value": 10.0 } } }
Queries on a aggregate_metric_double
field use the default_metric
value.
GET stats-index/_search { "query": { "term": { "agg_metric": { "value": 702.30 } } } }
The search returns the following hit. The value of the default_metric
field,
max
, matches the query value.
{ ... "hits": { "total": { "value": 1, "relation": "eq" }, "max_score": 1.0, "hits": [ { "_index": "stats-index", "_type": "_doc", "_id": "1", "_score": 1.0, "_source": { "agg_metric": { "min": -302.5, "max": 702.3, "sum": 200.0, "value_count": 25 } } } ] } }
