System call filter check
editElasticsearch installs system call filters of various flavors depending
on the operating system (e.g., seccomp on Linux). These system call
filters are installed to prevent the ability to execute system calls
related to forking as a defense mechanism against arbitrary code
execution attacks on Elasticsearch. The system call filter check ensures
that if system call filters are enabled, then they were successfully
installed. To pass the system call filter check you must either fix any
configuration errors on your system that prevented system call filters
from installing (check your logs), or at your own risk disable system
call filters by setting bootstrap.system_call_filter to false.
