Get rollup index capabilities APIedit
Returns the rollup capabilities of all jobs inside of a rollup index (e.g. the index where rollup data is stored).
Requestedit
GET <target>/_rollup/data
Prerequisitesedit
If the Elasticsearch security features are enabled, you must have the
read
index privilege on the index that stores the rollup results. For more information, see Security privileges.
Descriptionedit
A single rollup index may store the data for multiple rollup jobs, and may have a variety of capabilities depending on those jobs.
This API will allow you to determine:
- What jobs are stored in an index (or indices specified via a pattern)?
- What target indices were rolled up, what fields were used in those rollups and what aggregations can be performed on each job?
Path parametersedit
<target>
(Required, string) Data stream or index to check for rollup capabilities.
Wildcard (
) expressions are supported.
Examplesedit
Imagine we have an index named sensor-1
full of raw data. We know that the
data will grow over time, so there will be a sensor-2
, sensor-3
, etc.
Let’s create a rollup job that stores its data in sensor_rollup
PUT _rollup/job/sensor { "index_pattern": "sensor-*", "rollup_index": "sensor_rollup", "cron": "*/30 * * * * ?", "page_size": 1000, "groups": { "date_histogram": { "field": "timestamp", "fixed_interval": "1h", "delay": "7d" }, "terms": { "fields": [ "node" ] } }, "metrics": [ { "field": "temperature", "metrics": [ "min", "max", "sum" ] }, { "field": "voltage", "metrics": [ "avg" ] } ] }
If at a later date, we’d like to determine what jobs and capabilities were
stored in the sensor_rollup
index, we can use the get rollup index API:
GET /sensor_rollup/_rollup/data
Note how we are requesting the concrete rollup index name (sensor_rollup
) as
the first part of the URL. This will yield the following response:
{ "sensor_rollup" : { "rollup_jobs" : [ { "job_id" : "sensor", "rollup_index" : "sensor_rollup", "index_pattern" : "sensor-*", "fields" : { "node" : [ { "agg" : "terms" } ], "temperature" : [ { "agg" : "min" }, { "agg" : "max" }, { "agg" : "sum" } ], "timestamp" : [ { "agg" : "date_histogram", "time_zone" : "UTC", "fixed_interval" : "1h", "delay": "7d" } ], "voltage" : [ { "agg" : "avg" } ] } } ] } }
The response that is returned contains information that is similar to the original rollup configuration, but formatted differently. First, there are some house-keeping details: the rollup job ID, the index that holds the rolled data, the index pattern that the job was targeting.
Next it shows a list of fields that contain data eligible for rollup searches.
Here we see four fields: node
, temperature
, timestamp
and voltage
. Each
of these fields list the aggregations that are possible. For example, you can
use a min, max, or sum aggregation on the temperature
field, but only a
date_histogram
on timestamp
Note that the rollup_jobs
element is an array; there can be multiple,
independent jobs configured for a single index or index pattern. Each of these
jobs may have different configurations, so the API returns a list of all the
various configurations available.
Like other APIs that interact with indices, you can specify index patterns instead of explicit indices:
GET /*_rollup/_rollup/data
