WARNING: Version 6.2 of Elasticsearch has passed its EOL date.
Advanced scripts using script enginesedit
A ScriptEngine
is a backend for implementing a scripting language. It may also
be used to write scripts that need to use advanced internals of scripting. For example,
a script that wants to use term frequencies while scoring.
The plugin documentation has more information on
how to write a plugin so that Elasticsearch will properly load it. To register
the ScriptEngine
, your plugin should implement the ScriptPlugin
interface
and override the getScriptEngine(Settings settings)
method.
The following is an example of a custom ScriptEngine
which uses the language
name expert_scripts
. It implements a single script called pure_df
which
may be used as a search script to override each document’s score as
the document frequency of a provided term.
private static class MyExpertScriptEngine implements ScriptEngine { @Override public String getType() { return "expert_scripts"; } @Override public <T> T compile(String scriptName, String scriptSource, ScriptContext<T> context, Map<String, String> params) { if (context.equals(SearchScript.CONTEXT) == false) { throw new IllegalArgumentException(getType() + " scripts cannot be used for context [" + context.name + "]"); } // we use the script "source" as the script identifier if ("pure_df".equals(scriptSource)) { SearchScript.Factory factory = (p, lookup) -> new SearchScript.LeafFactory() { final String field; final String term; { if (p.containsKey("field") == false) { throw new IllegalArgumentException("Missing parameter [field]"); } if (p.containsKey("term") == false) { throw new IllegalArgumentException("Missing parameter [term]"); } field = p.get("field").toString(); term = p.get("term").toString(); } @Override public SearchScript newInstance(LeafReaderContext context) throws IOException { PostingsEnum postings = context.reader().postings(new Term(field, term)); if (postings == null) { // the field and/or term don't exist in this segment, so always return 0 return new SearchScript(p, lookup, context) { @Override public double runAsDouble() { return 0.0d; } }; } return new SearchScript(p, lookup, context) { int currentDocid = -1; @Override public void setDocument(int docid) { // advance has undefined behavior calling with a docid <= its current docid if (postings.docID() < docid) { try { postings.advance(docid); } catch (IOException e) { throw new UncheckedIOException(e); } } currentDocid = docid; } @Override public double runAsDouble() { if (postings.docID() != currentDocid) { // advance moved past the current doc, so this doc has no occurrences of the term return 0.0d; } try { return postings.freq(); } catch (IOException e) { throw new UncheckedIOException(e); } } }; } @Override public boolean needs_score() { return false; } }; return context.factoryClazz.cast(factory); } throw new IllegalArgumentException("Unknown script name " + scriptSource); } @Override public void close() { // optionally close resources } }
You can execute the script by specifying its lang
as expert_scripts
, and the name
of the script as the script source:
POST /_search { "query": { "function_score": { "query": { "match": { "body": "foo" } }, "functions": [ { "script_score": { "script": { "source": "pure_df", "lang" : "expert_scripts", "params": { "field": "body", "term": "foo" } } } } ] } } }
