WARNING: Version 6.0 of Elasticsearch has passed its EOL date.
Tune for search speededit
Give memory to the filesystem cacheedit
Elasticsearch heavily relies on the filesystem cache in order to make search fast. In general, you should make sure that at least half the available memory goes to the filesystem cache so that Elasticsearch can keep hot regions of the index in physical memory.
Use faster hardwareedit
If your search is I/O bound, you should investigate giving more memory to the
filesystem cache (see above) or buying faster drives. In particular SSD drives
are known to perform better than spinning disks. Always use local storage,
remote filesystems such as NFS
or SMB
should be avoided. Also beware of
virtualized storage such as Amazon’s Elastic Block Storage
. Virtualized
storage works very well with Elasticsearch, and it is appealing since it is so
fast and simple to set up, but it is also unfortunately inherently slower on an
ongoing basis when compared to dedicated local storage. If you put an index on
EBS
, be sure to use provisioned IOPS otherwise operations could be quickly
throttled.
If your search is CPU-bound, you should investigate buying faster CPUs.
Document modelingedit
Documents should be modeled so that search-time operations are as cheap as possible.
In particular, joins should be avoided. nested
can make queries
several times slower and parent-child relations can make
queries hundreds of times slower. So if the same questions can be answered without
joins by denormalizing documents, significant speedups can be expected.
Pre-index dataedit
You should leverage patterns in your queries to optimize the way data is indexed.
For instance, if all your documents have a price
field and most queries run
range
aggregations on a fixed
list of ranges, you could make this aggregation faster by pre-indexing the ranges
into the index and using a terms
aggregations.
For instance, if documents look like:
PUT index/type/1 { "designation": "spoon", "price": 13 }
and search requests look like:
GET index/_search { "aggs": { "price_ranges": { "range": { "field": "price", "ranges": [ { "to": 10 }, { "from": 10, "to": 100 }, { "from": 100 } ] } } } }
Then documents could be enriched by a price_range
field at index time, which
should be mapped as a keyword
PUT index { "mappings": { "type": { "properties": { "price_range": { "type": "keyword" } } } } } PUT index/type/1 { "designation": "spoon", "price": 13, "price_range": "10-100" }
And then search requests could aggregate this new field rather than running a
range
aggregation on the price
field.
GET index/_search { "aggs": { "price_ranges": { "terms": { "field": "price_range" } } } }
Mappingsedit
The fact that some data is numeric does not mean it should always be mapped as a
numeric field. Typically, fields storing identifiers such as an ISBN
or any number identifying a record from another database, might benefit from
being mapped as keyword
rather than integer
or long
Avoid scriptsedit
In general, scripts should be avoided. If they are absolutely needed, you
should prefer the painless
and expressions
engines.
Search rounded datesedit
Queries on date fields that use now
are typically not cacheable since the
range that is being matched changes all the time. However switching to a
rounded date is often acceptable in terms of user experience, and has the
benefit of making better use of the query cache.
For instance the below query:
PUT index/type/1 { "my_date": "2016-05-11T16:30:55.328Z" } GET index/_search { "query": { "constant_score": { "filter": { "range": { "my_date": { "gte": "now-1h", "lte": "now" } } } } } }
could be replaced with the following query:
GET index/_search { "query": { "constant_score": { "filter": { "range": { "my_date": { "gte": "now-1h/m", "lte": "now/m" } } } } } }
In that case we rounded to the minute, so if the current time is 16:31:29
the range query will match everything whose value of the my_date
field is
between 15:31:00
and 16:31:59
. And if several users run a query that
contains this range in the same minute, the query cache could help speed things
up a bit. The longer the interval that is used for rounding, the more the query
cache can help, but beware that too aggressive rounding might also hurt user
experience.
It might be tempting to split ranges into a large cacheable part and smaller not cacheable parts in order to be able to leverage the query cache, as shown below:
GET index/_search { "query": { "constant_score": { "filter": { "bool": { "should": [ { "range": { "my_date": { "gte": "now-1h", "lte": "now-1h/m" } } }, { "range": { "my_date": { "gt": "now-1h/m", "lt": "now/m" } } }, { "range": { "my_date": { "gte": "now/m", "lte": "now" } } } ] } } } } }
However such practice might make the query run slower in some cases since the
overhead introduced by the bool
query may defeat the savings from better
leveraging the query cache.
Force-merge read-only indicesedit
Indices that are read-only would benefit from being merged down to a single segment. This is typically the case with time-based indices: only the index for the current time frame is getting new documents while older indices are read-only.
Don’t force-merge indices that are still being written to — leave merging to the background merge process.
Warm up global ordinalsedit
Global ordinals are a data-structure that is used in order to run
terms
aggregations on
keyword
fields. They are loaded lazily in memory because
Elasticsearch does not know which fields will be used in terms
aggregations
and which fields won’t. You can tell Elasticsearch to load global ordinals
eagerly at refresh-time by configuring mappings as described below:
PUT index { "mappings": { "type": { "properties": { "foo": { "type": "keyword", "eager_global_ordinals": true } } } } }
Warm up the filesystem cacheedit
If the machine running Elasticsearch is restarted, the filesystem cache will be
empty, so it will take some time before the operating system loads hot regions
of the index into memory so that search operations are fast. You can explicitly
tell the operating system which files should be loaded into memory eagerly
depending on the file extension using the index.store.preload
setting.
Loading data into the filesystem cache eagerly on too many indices or too many files will make search slower if the filesystem cache is not large enough to hold all the data. Use with caution.
Map identifiers as keyword
When you have numeric identifiers in your documents, it is tempting to map them
as numbers, which is consistent with their json type. However, the way that
Elasticsearch indexes numbers optimizes for range
queries while keyword
fields are better at term
queries. Since identifiers are never used in range
queries, they should be mapped as a keyword
Use index sorting to speed up conjunctionsedit
Index sorting can be useful in order to make conjunctions faster at the cost of slightly slower indexing. Read more about it in the index sorting documentation.
Use preference
to optimize cache utilizationedit
There are multiple caches that can help with search performance, such as the filesystem cache, the request cache or the query cache. Yet all these caches are maintained at the node level, meaning that if you run the same request twice in a row, have 1 replica or more and use round-robin, the default routing algorithm, then those two requests will go to different shard copies, preventing node-level caches from helping.
Since it is common for users of a search application to run similar requests one after another, for instance in order to analyze a narrower subset of the index, using a preference value that identifies the current user or session could help optimize usage of the caches.
Replicas might help with throughput, but not alwaysedit
In addition to improving resiliency, replicas can help improve throughput. For instance if you have a single-shard index and three nodes, you will need to set the number of replicas to 2 in order to have 3 copies of your shard in total so that all nodes are utilized.
Now imagine that you have a 2-shards index and two nodes. In one case, the number of replicas is 0, meaning that each node holds a single shard. In the second case the number of replicas is 1, meaning that each node has two shards. Which setup is going to perform best in terms of search performance? Usually, the setup that has fewer shards per node in total will perform better. The reason for that is that it gives a greater share of the available filesystem cache to each shard, and the filesystem cache is probably Elasticsearch’s number 1 performance factor. At the same time, beware that a setup that does not have replicas is subject to failure in case of a single node failure, so there is a trade-off between throughput and availability.
So what is the right number of replicas? If you have a cluster that has
num_nodes
nodes, num_primaries
primary shards in total and if you want to
be able to cope with max_failures
node failures at once at most, then the
right number of replicas for you is
max(max_failures, ceil(num_nodes / num_primaries) - 1)
Tune your queries with the Profile APIedit
You can also analyse how expensive each component of your queries and aggregations are using the Profile API. This might allow you to tune your queries to be less expensive, resulting in a positive performance result and reduced load. Also note that Profile API payloads can be easily visualised for better readability in the Search Profiler, which is a Kibana dev tools UI available in all X-Pack licenses, including the free X-Pack Basic license.
Some caveats to the Profile API are that:
- the Profile API as a debugging tool adds significant overhead to search execution and can also have a very verbose output
- given the added overhead, the resulting took times are not reliable indicators of actual took time, but can be used comparatively between clauses for relative timing differences
- the Profile API is best for exploring possible reasons behind the most costly clauses of a query but isn’t intended for accurately measuring absolute timings of each clause
