WARNING: Version 5.6 of Elasticsearch has passed its EOL date.
Remote Cluster Infoedit
The cluster remote info API allows to retrieve all of the configured remote cluster information.
GET /_remote/info
This command returns returns connection and endpoint information keyed by the configured remote cluster alias.
seeds
- The configured initial seed transport addresses of the remote cluster.
http_addresses
- The published http addresses of all connected remote nodes.
connected
- True if there is at least one connection to the remote cluster.
num_nodes_connected
- The number of connected nodes in the remote cluster.
max_connection_per_cluster
- The maximum number of connections maintained for the remote cluster.
initial_connect_timeout
- The initial connect timeout for remote cluster connections.
