WARNING: Version 5.1 of Elasticsearch has passed its EOL date.
Tune for search speededit
Give memory to the filesystem cacheedit
Elasticsearch heavily relies on the filesystem cache in order to make search fast. In general, you should make sure that at least half the available memory goes to the filesystem cache so that elasticsearch can keep hot regions of the index in physical memory.
Use faster hardwareedit
If your search is I/O bound, you should investigate giving more memory to the
filesystem cache (see above) or buying faster drives. In particular SSD drives
are known to perform better than spinning disks. Always use local storage,
remote filesystems such as NFS
or SMB
should be avoided. Also beware of
virtualized storage such as Amazon’s Elastic Block Storage
. Virtualized
storage works very well with Elasticsearch, and it is appealing since it is so
fast and simple to set up, but it is also unfortunately inherently slower on an
ongoing basis when compared to dedicated local storage. If you put an index on
EBS
, be sure to use provisioned IOPS otherwise operations could be quickly
throttled.
If your search is CPU-bound, you should investigate buying faster CPUs.
Document modelingedit
Documents should be modeled so that search-time operations are as cheap as possible.
In particular, joins should be avoided. nested
can make queries
several times slower and parent-child relations can make
queries hundreds of times slower. So if the same questions can be answered without
joins by denormalizing documents, significant speedups can be expected.
Pre-index dataedit
You should leverage patterns in your queries to optimize the way data is indexed.
For instance, if all your documents have a price
field and most queries run
range
aggregations on a fixed
list of ranges, you could make this aggregation faster by pre-indexing the ranges
into the index and using a terms
aggregations.
For instance, if documents look like:
PUT index/type/1 { "designation": "spoon", "price": 13 }
and search requests look like:
GET index/_search { "aggs": { "price_ranges": { "range": { "field": "price", "ranges": [ { "to": 10 }, { "from": 10, "to": 100 }, { "from": 100 } ] } } } }
Then documents could be enriched by a price_range
field at index time, which
should be mapped as a keyword
PUT index { "mappings": { "type": { "properties": { "price_range": { "type": "keyword" } } } } } PUT index/type/1 { "designation": "spoon", "price": 13, "price_range": "10-100" }
And then search requests could aggregate this new field rather than running a
range
aggregation on the price
field.
GET index/_search { "aggs": { "price_ranges": { "terms": { "field": "price_range" } } } }
Mappingsedit
The fact that some data is numeric does not mean it should always be mapped as a
numeric field. Typically, fields storing identifiers such as an ISBN
or any number identifying a record from another database, might benefit from
being mapped as keyword
rather than integer
or long
Avoid scriptsedit
In general, scripts should be avoided. If they are absolutely needed, you
should prefer the painless
and expressions
engines.
Search rounded datesedit
Queries on date fields that use now
are typically not cacheable since the
range that is being matched changes all the time. However switching to a
rounded date is often acceptable in terms of user experience, and has the
benefit of making better use of the query cache.
For instance the below query:
PUT index/type/1 { "my_date": "2016-05-11T16:30:55.328Z" } GET index/_search { "query": { "constant_score": { "filter": { "range": { "my_date": { "gte": "now-1h", "lte": "now" } } } } } }
could be replaced with the following query:
GET index/_search { "query": { "constant_score": { "filter": { "range": { "my_date": { "gte": "now-1h/m", "lte": "now/m" } } } } } }
In that case we rounded to the minute, so if the current time is 16:31:29
the range query will match everything whose value of the my_date
field is
between 15:31:00
and 16:31:59
. And if several users run a query that
contains this range in the same minute, the query cache could help speed things
up a bit. The longer the interval that is used for rounding, the more the query
cache can help, but beware that too aggressive rounding might also hurt user
experience.
It might be tempting to split ranges into a large cacheable part and smaller not cacheable parts in order to be able to leverage the query cache, as shown below:
GET index/_search { "query": { "constant_score": { "filter": { "bool": { "should": [ { "range": { "my_date": { "gte": "now-1h", "lte": "now-1h/m" } } }, { "range": { "my_date": { "gt": "now-1h/m", "lt": "now/m" } } }, { "range": { "my_date": { "gte": "now/m", "lte": "now" } } } ] } } } } }
However such practice might make the query run slower in some cases since the
overhead introduced by the bool
query may defeat the savings from better
leveraging the query cache.
Force-merge read-only indicesedit
Indices that are read-only would benefit from being merged down to a single segment. This is typically the case with time-based indices: only the index for the current time frame is getting new documents while older indices are read-only.
Don’t force-merge indices that are still being written to — leave merging to the background merge process.
Warm up global ordinalsedit
Global ordinals are a data-structure that is used in order to run
terms
aggregations on
keyword
fields. They are loaded lazily in memory because
elasticsearch does not know which fields will be used in terms
aggregations
and which fields won’t. You can tell elasticsearch to load global ordinals
eagerly at refresh-time by configuring mappings as described below:
PUT index { "mappings": { "type": { "properties": { "foo": { "type": "keyword", "eager_global_ordinals": true } } } } }
Warm up the filesystem cacheedit
If the machine running elasticsearch is restarted, the filesystem cache will be
empty, so it will take some time before the operating system loads hot regions
of the index into memory so that search operations are fast. You can explicitly
tell the operating system which files should be loaded into memory eagerly
depending on the file extension using the index.store.preload
setting.
Loading data into the filesystem cache eagerly on too many indices or too many files will make search slower if the filesystem cache is not large enough to hold all the data. Use with caution.
