WARNING: Version 2.3 of Elasticsearch has passed its EOL date.
Multiple Indicesedit
Most APIs that refer to an index
parameter support execution across multiple indices,
using simple test1,test2,test3
notation (or _all
for all indices). It also
support wildcards, for example: test*
or *test
or te*t
or *test*
, and the ability to "add" (+
and "remove" (-
), for example: +test*,-test3
All multi indices API support the following url query string parameters:
ignore_unavailable
Controls whether to ignore if any specified indices are unavailable, this
includes indices that don’t exist or closed indices. Either
true
orfalse
can be specified. -
allow_no_indices
Controls whether to fail if a wildcard indices expressions results into no
concrete indices. Either
true
orfalse
can be specified. For example if the wildcard expressionfoo*
is specified and no indices are available that start withfoo
then depending on this setting the request will fail. This setting is also applicable when_all
or no index has been specified. This settings also applies for aliases, in case an alias points to a closed index. -
expand_wildcards
Controls to what kind of concrete indices wildcard indices expression expand
to. If
open
is specified then the wildcard expression is expanded to only open indices and ifclosed
is specified then the wildcard expression is expanded only to closed indices. Also both values (open,closed
) can be specified to expand to all indices.
If none
is specified then wildcard expansion will be disabled and if all
is specified, wildcard expressions will expand to all indices (this is equivalent
to specifying open,closed
The defaults settings for the above parameters depend on the api being used.
Single index APIs such as the Document APIs and the
single-index alias
APIs do not support multiple indices.
