WARNING: Version 2.2 of Elasticsearch has passed its EOL date.
index
The index
option controls how field values are indexed and, thus, how they
are searchable. It accepts three values:
Do not add this field value to the index. With this setting, the field will not be queryable. |
Add the field value to the index unchanged, as a single term. This is the
default for all fields that support this option except for
This option applies only to |
For example, you can create a not_analyzed
string field with the following:
PUT /my_index { "mappings": { "my_type": { "properties": { "status_code": { "type": "string", "index": "not_analyzed" } } } } }
