Index management settingsedit
You can use the following cluster settings to enable or disable index management features.
action.auto_create_index
(Dynamic)
Automatically create an index if it doesn’t already exist and apply any configured index templates. Defaults to
true
action.destructive_requires_name
(Dynamic)
When set to
true
, you must specify the index name to delete an index. It is not possible to delete all indices with_all
or use wildcards. Defaults totrue
cluster.indices.close.enable
(Dynamic) Enables closing of open indices in Elasticsearch. If
false
, you cannot close open indices. Defaults totrue
.Closed indices still consume a significant amount of disk space.
reindex.remote.whitelist
(Static)
Specifies the hosts that can be reindexed from remotely. Expects a YAML array of
host:port
strings. Consists of a comma-delimited list ofhost:port
entries. Defaults to["\*.io:*", "\*.com:*"]
stack.templates.enabled
(Dynamic) If
true
, enables built-in index and component templates. Elastic Agent uses these templates to create data streams. Iffalse
, Elasticsearch disables these index and component templates. Defaults totrue
.This setting affects the following built-in index templates:
logs-*-*
metrics-*-*
synthetics-*-*
profiling-*
This setting also affects the following built-in component templates:
logs@mappings
logs@settings
metrics@mappings
metrics@settings
metrics@tsdb-settings
synthetics@mapping
synthetics@settings
