WARNING: The 1.x versions of Elasticsearch have passed their EOL dates. If you are running a 1.x version, we strongly advise you to upgrade.
This documentation is no longer maintained and may be removed. For the latest information, see the current Elasticsearch documentation.
Multi-index, Multitypeedit
Did you notice that the results from the preceding empty search
contained documents of different types—user
and tweet
—from two
different indices—us
and gb
By not limiting our search to a particular index or type, we have searched across all documents in the cluster. Elasticsearch forwarded the search request in parallel to a primary or replica of every shard in the cluster, gathered the results to select the overall top 10, and returned them to us.
Usually, however, you will want to search within one or more specific indices, and probably one or more specific types. We can do this by specifying the index and type in the URL, as follows:
/_search
- Search all types in all indices
/gb/_search
Search all types in the
gb
index -
/gb,us/_search
gb
andus
indices -
/g*,u*/_search
Search all types in any indices beginning with
g
or beginning withu
/gb/user/_search
Search type
user
in thegb
index -
/gb,us/user,tweet/_search
Search types
user
andtweet
in thegb
andus
indices -
/_all/user,tweet/_search
Search types
user
andtweet
in all indices
When you search within a single index, Elasticsearch forwards the search request to a primary or replica of every shard in that index, and then gathers the results from each shard. Searching within multiple indices works in exactly the same way—there are just more shards involved.
Searching one index that has five primary shards is exactly equivalent to searching five indices that have one primary shard each.
Later, you will see how this simple fact makes it easy to scale flexibly as your requirements change.
